IX Stock Block, 64mm Red, Boltons
This is true. I went 11.0@123.5mph on my stock turbo with a 1.64 60ft. You have the mph for a 10.8 with a solid 1.6 60ft and fast shifting.
No this was on my track tune which got me 481/379...Based on how the car felt, I know I've got enough power to hit very low 11's possibly high 10's as it stands now...but definitely going to need some tires, especially if they aren't going to prep the track either.
Nice time on your red..yea the 60ft is a killer. I did 7.39 @ 95.34mph in the 1/8th...what about you?
Nope, this is the factory MR 6spd...
Definitely got to do some work on my 60ft, play around with the launch maps a bit once I get the tires.
I'm on 235/40/18 Federal 595RS's (19psi all around) w/custom revalved Bilsteins and Hotchkis springs...(think I might try a set of stiffer springs at the track next time though)
Yup, but I have to be running out 4th to where I'm not so comfortable with...the taller tires should give me a little breathing room.
thanks for the info and join that 10sec club already
Definitely...I already bought a set of 1K's from a fellow evoM member and should be throwing them in very soon...I'll post the results
It's tons of fun to drive, stock frame ftw..
Quick question for you guys, if I'm planning on upgrading the cover to the 84mm, does it matter if I go ahead and scale the injectors on the 64mm and then switch to the 84mm later on? The difference in airflow hz at idle shouldn't affect the trims should it?
FP just told me yesterday that the 84MM and they just told me that the flow would equal up to 30WHP. 1000's may be too small. I just purchased 1150's from FIC. That should do it.
I'm pretty sure that I'll have enough fuel now though with the 1K's + meth...thanks for the heads up though.
Hmmm, sounds like I may just wait a little and throw on both at the same time.
Well considering that I can only get 90oct at the pump I'm forced to flow a good deal of meth (approx. 700cc/min) to make up.
what was your 1\8 et and mph. you must have VIII 3RD&4TH?? good luck gettin into the 10s
