MAP EF4 e85 built 2L tuned by tscompusa/vr-speed
Old Jan 26, 2012 | 03:37 PM
  #151
maperformance's Avatar
Check the last email I sent you. If the actuator doesn't fix your issue, then we will trouble shoot it not a problem.
Old Jan 26, 2012 | 03:43 PM
  #152
CurseDSM's Avatar
Originally Posted by burnzy
Anyone else having wastegate issues on their ef4? Mine hits 20psi at 4500 then takes anothe 1000rpm to get to 28 psi on. 2.4litre long rod
Do you have the proper preload on it. I know mine did that and I did not have proper preload.
Old Jan 26, 2012 | 04:13 PM
  #153
The problem is he got a 1 bar version of our stamped wastegate actuators and it is supposed to be a 25psi.
Old Jan 26, 2012 | 04:19 PM
  #154
CurseDSM's Avatar
Ah makes since yeah that will do it for sure.
Old Jan 26, 2012 | 04:27 PM
  #155
tscompusa's Avatar
i was gonna say..... they fixed the wastegate stuff awhile ago lol.
Old Jan 26, 2012 | 10:16 PM
  #156
burnzy's Avatar
what i don't get is I put a known 24psi wastegate on, preloaded it, and it only showed 17psi, the length of the wastegate arm seems to have to be longer for the ef4 than standard e9 framed turbo. made 0 difference to spoolup, what else can cause this besides boost leak? checked cat wasn't clogged. Does the ef4 have more backpressure than other stock frame turbos, forcing gates open? Have to add though, adam @ map has been more than helpful in regards to my issue, I'm sure we'll get it sorted out! Just wanted a few tips from anyone else if they had this problem and how it was fixed thats all.
Old Jan 27, 2012 | 06:37 AM
  #157
24psi wastegate on one turbo is not going to be the same on another. What did the "24psi wastegate" come off of? What turbo?
Old Jan 27, 2012 | 06:53 AM
  #158
burnzy's Avatar
Came off a bbk full, not a stock bbk actuator thought its marketed as a 1.7 bar, bought it from
Kando/kinugawa. had to extend it for this turbo as
When I first put it on the arm wouldn't even extend enough. It held 25psi straight off the gate with bbk.
Old Jan 27, 2012 | 08:08 AM
  #159
Well if you had to extend it that alone is your problem. Your taking the preload off it that it had when using it on a BBK full. We use different compressor housings as we have anti-surge inlets. So the actuator is not going to be the same for every turbo.
Plus it is very possible if you extended it to far the wastegate flapper wasn't 100% closed when you fired up the car. Causing it to spool even worse!
When you get the new actuator from us, start off by holding the flapper shut completely. Then make the actuator just fit with all the holes lined up. Then take it back off and crank it down about 4 full turns. This should give you a little preload to start off with, and run it without any sort of boost control source, just run a straight vacuum/boost line. Document the boost at this level and report back!
Old Jan 27, 2012 | 04:47 PM
  #160
burnzy's Avatar
I know how to preload a turbo. When I say extended It was extended to fall 3/4 of a hole short of the closed gate. It wouldn't mak any difference on the spring the preload is determined by the length between the closed gate and the eyelet, shouldn't matter how long the arm
Is the spring is still compressed and the gate is still being pulled on. I even tried preloading the first wastegate to 19psi but it didn't make a difference. I've ran out of options now so just crossing fingers actuator fixes it.
Old Jan 28, 2012 | 04:04 AM
  #161
94AWDcoupe's Avatar
you can try wiring the gate closed. see if that speeds boost curve. but is sounds like your problem is elsewhere. maybe exhaust restriction . maybe a boost leak. like BOV not holding. you can block off that as well for quick test.
Old Jan 28, 2012 | 02:39 PM
  #162
ChrisCarey's Avatar
Either way sir we will stand behind our product, I apologize for the inconvenience.
Old Jan 29, 2012 | 06:18 AM
  #163
94AWDcoupe's Avatar
now my guess would be there is nothing wrong at all. this turbo is just a laggy beast. here is a recent graph posted of the turbo in 3rd and 4th gears. look how laggy third gear boost curve is. this is a perfect example of why this turbo is a turd. the car is well setup/tuned car that makes fantastic power in forth. but there is something wrong with the turbo combination to look that bad in 3rd gear.
Old Jan 29, 2012 | 08:28 AM
  #164
Levar's Avatar
Veteran: Army
OK. I have read every post in this thread. I will not entertain any of the trash talking. I am more concerned about whether the OP just has some minor porting work done to the head or a full Stage 3 or Stage 5...? Thanks.
Old Jan 30, 2012 | 08:05 AM
  #165
Please shoot me a graph of what you think acceptable spool would be on a stock frame turbo that makes over 700whp.
42psi by 3600rpm's in 4th gear pull starting at 2200rpm's doesn't really seem like that would be this turbo in the category of a turd.
The person's graph that you posted is completely happy with the turbo and comments on how fast it spools all the time.
It seems as if you have no support for stock frame turbo's going by your posts on the forum.
