MAP EF4 e85 built 2L tuned by tscompusa/vr-speed
Old Feb 2, 2012 | 10:26 PM
  #211
Levar's Avatar
Veteran: Army
Originally Posted by Svendiesel
I wasnt really pushing the blocks' power limits either, car was making like 390/390.
Man, that is horrible right there and goes to show that not all 4G63 blocks are made the same out of the factory. Some blocks just "survive" the abuse and others..., well... This factor alone is reason for me to get a built block (even if it is a used one) just for the added peace of mind.
Old Feb 3, 2012 | 12:33 AM
  #212
Svendiesel's Avatar
Well, mine let go because my meth pump lost prime at WOT lol. Wasn't the blocks fault. Worst part is I had a brand new pump wired up ready to go in and I didn't get around to putting it in in time. Oh well lol.
Old Feb 3, 2012 | 05:27 AM
  #213
Levar's Avatar
Veteran: Army
OK. Totally understand and makes me feel much better.
Old Apr 4, 2013 | 03:51 AM
  #214
RussellDaniel's Avatar
will the ef4 hold out 38 psi with a external wastegate to redline?
Old Apr 8, 2013 | 01:37 AM
  #215
tscompusa's Avatar
If you want to do that you have to use a 3 port. that is really putting a lot of stress on the turbo also. it might be ok with a 2.0L but if you have a larger displacement engine like a 2.3-2.4 its not really recommended for the long run of the turbo.
I ran my fp black at 36-37 solid to redline and its still fine, but its a ball bearing garrett center section. i dont know how long a EF4 would hold up at 38psi at high RPM. the shaft speeds are probably well into the danger zone.
Old Apr 8, 2013 | 09:55 AM
  #216
Tom that's dissapoining considering the advertised rating far exceeds the 594 im putting down now. I have the right set up now to make this turbo roar. Hopefully the dump tube and external gate will do something..also im running a 3port in conjunction with manual boost controller. I just wonder if my internal wastegate 18 psi just isn't gonna do the trick. We will see next week if the external helps. Ill post results.
Old Apr 9, 2013 | 07:11 AM
  #217
maperformance's Avatar
Sorry.... Definitely didn't mean to bump this.
Old Apr 9, 2013 | 06:36 PM
  #218
tschad's Avatar
Seems to make decent power, wonder how it compares to a black
Old Apr 9, 2013 | 06:41 PM
  #219
CurseDSM's Avatar
Well being it has been done many of times all you have to do is search. The op doesn't even own this car anymore and this thread is pretty old. I know Marlo made 650 whp in his on a 2.4 and I know the turbo will do more then that.
Old Apr 9, 2013 | 07:11 PM
  #220
bump
Old Apr 9, 2013 | 07:38 PM
  #221
murlo26's Avatar
You didn't mean Murlo did you? LOL, sorry it was close to me so I wasn't sure haha. Maybe just another ef4 that made 650.
Old Apr 9, 2013 | 10:34 PM
  #222
steven0720's Avatar
Looks good for the power , any chance compare with Pro efi tune??
Old Apr 10, 2013 | 09:20 AM
  #223
CurseDSM's Avatar
Yeah I did My mind went blank on the screen name hahahaha sorry about that. I know your car is no joke and all and I know your runnin what the guy is lookin for.
Old Apr 10, 2013 | 10:21 AM
  #224
murlo26's Avatar
I have a 2.2 and its an X. So I was a bit confused
Old Apr 10, 2013 | 10:29 AM
  #225
CurseDSM's Avatar
I know I just knew you ran an ef4 with a something or another setup
