Borgwarner Twin Scroll 7670 With Dyno Graph
Old Nov 3, 2011 | 11:36 AM
  #391
L888Apex's Avatar
Originally Posted by Drifting Away
Ben....
When are we going to the track lol
HIT ME UP BLACK STEVE HAHA!!!!
Old Nov 3, 2011 | 12:17 PM
  #392
bevolucion's Avatar
how many concutions have you experimented with this set up?, because I imagine that a torque pull like that there is definetly brain to cranium contact.
Old Nov 6, 2011 | 07:19 AM
  #393
leetEVO's Avatar
I can say the car is stinking fast. First two sessions of the shake down run were great. Went out for the third session, hit the back straight and see a m3 passing me while at WOT. I'm thinking wait how is that even possible (Nobody could even come close to my backstraight speed.)Look down.... 0 boost and a supercharger like whine. Limped it in to see if it was any easy fix.
Luckliy I had the guys from RRE down doing track support so they checked and found no boost leaks and from the intake side it looks like the wheel started digging in to the inside of the housing. It SO hard to see. Running the car, There is a heavy metalic like whine, and with the intake off and putting your hand over the intake side it definently sucks... no leaks everything bulges like it should. The one interesting thing is that when you stop the car... the wheel just stops instantly... typically I was told on a BB turbo the wheel keeps spining.. this just comes to an abrudt stop.
So the car is headed back down to RRE for the turbo to be removed and inspected... But if it was damaged from the original issue, I'm wondering if that may have been part less then stellar results? I don't really know... but I'm trying my hardest to get a solution together before Tuesday.
Old Nov 6, 2011 | 07:26 AM
  #394
SWOLN's Avatar
^^^ Bummer!
Old Nov 6, 2011 | 08:17 AM
  #395
Jason's Avatar
Wow just wow. Sorry to hear man
Old Nov 6, 2011 | 08:28 AM
  #396
metalsaber's Avatar
Very much a possibility.
Old Nov 6, 2011 | 08:29 AM
  #397
deeman101's Avatar
That truly sucks man. Sorry for all your setbacks, must be truly disheartening.
Hopefully you're only a turbo swap away from miles of trouble free racing!
Old Nov 6, 2011 | 09:24 AM
  #398
n2oiroc's Avatar
Was the oil cooler replaced?
Old Nov 6, 2011 | 09:26 AM
  #399
leetEVO's Avatar
Yes sir. No way I'm going to cheap out and try and save $300 lol.
Old Nov 6, 2011 | 09:47 AM
  #400
n2oiroc's Avatar
I figured you would, and that david buschur would insist on it but someone had to ask a stupid question.
Old Nov 6, 2011 | 11:40 AM
  #401
leetEVO's Avatar
So, the turbo is off and as far as RRE can tell the bearings are fine. The turbo does not spin because the shaft is bent. That is making it bind on the bearings. One sise of the compressor wheel has relatively undamaged blades. They do not contact the housing. On the opposite side of the wheel the blades are all ground away. We are pretty sure that it wasn't caused by the prior motor’s death.
To be continued:
http://youtu.be/B7XQq5G7VCA
Old Nov 6, 2011 | 12:11 PM
  #402
Beetspeed's Avatar
Thats really NOT good; curieus what happened to/with this turbo.
Maybe send it back to BW/FullRace so they can diagnose it?
Old Nov 6, 2011 | 12:12 PM
  #403
JARVEVO8's Avatar
To be continued:
What happen to that Turbo man?
Definitely To be continued!
Im so sorry to hear this Leet! Don't quit!!!!
Old Nov 6, 2011 | 12:22 PM
  #404
eTiLiKo's Avatar
There wasn't another EFR with bent shaft in the UK?
Old Nov 6, 2011 | 12:37 PM
  #405
evosdad's Avatar
I was just going to say that ^ +1
