Borgwarner Twin Scroll 7670 With Dyno Graph
Old Nov 9, 2011 | 02:24 PM
  #496
dtrackstar's Avatar
Originally Posted by David Buschur
The engine didn't "blow up", saying that means it failed. Ben says the spark plugs burnt the ends off. That is a "tuning" issue. The problem for me is I tuned it and I know how soft the tune was that it left here with. I can say with complete certainty that it there is no way in hell it could burn the plugs off (detonate) with the tune I had in it, just not happening. 27 psi of boost peak falling to 22 psi, 9 degrees timing going up to 13 degrees on a decent sized turbo, big FMIC, great cams and E85, AFR's in the 11.7:1 range. That is not hurting an engine end of story. Knock control was set up very aggressive allowing the engine to add 15% fuel and pull 10 degrees of timing. I set this car up conservatively to make sure it was going to run a good long time.
Something changed. FPR hose blew off, double pumper somehow didn't trigger, tune was changed, turbo flows more than the last one..........I don't know. I do know the engine stayed together and there is no explanation for the tune to run two 20 minute sessions one week perfectly and then melt the plugs off in less than 10 laps.
I have offered to fix the car out of my pocket if Ben wants to bring it back here. I am beyond pissed off this has happened. I think the next time this car goes to the track I am going to arrange to be there.
^^^ That's customer service. That's why I'll be running a BR block when I'm ready to buy
Old Nov 9, 2011 | 07:07 PM
  #497
juanmedina's Avatar
wow sorry dude.
Old Nov 9, 2011 | 07:12 PM
  #498
n2oiroc's Avatar
Originally Posted by R/TErnie
The first turbo failure is most likely due to the FIRST engine failure putting rod bearings and oil pump pieces through the CHRA via the unfiltered oil feed line to the turbocharger.
how would that bend the shaft? backpressure imbalance?
Old Nov 10, 2011 | 01:11 AM
  #499
joyce1bro's Avatar
+10000 Ima do the same... just need the money for the 2.3RPM and then its on
Old Nov 10, 2011 | 04:26 AM
  #500
94AWDcoupe's Avatar
One thing changed since Dave tuned it last... the turbocharger.
It's obvious that the turbocharger was damaged when you tuned it Dave. Explains the difference in the tune, the 2nd engine failure, the lack of response on your dyno (why the EFR spools slower in 4th gear than the HTA3076 did in 3rd gear), etc.
It's a shame eyecrometers don't accurately measure radial and axial shaft play.
I hope to see Ben's car out and running soon.
Gotta disagree with you on this one. When turbos bend a shaft they are useless instantly. Wont spin up at all from the serious imbalance. If it tries to it will self destruct . From having 30 years turbo experience, there is no such thing as slightly damaged turbo that would be down on power. Only thing I can think of that would hurt power without causing instant failure is ingestion that bent all the intake blades evenly enough so as to be able to spool without self destructing. Simply not the case here...
Old Nov 10, 2011 | 06:25 AM
  #501
R/TErnie's Avatar
haha, OK.
Old Nov 10, 2011 | 09:21 AM
  #502
JARVEVO8's Avatar
x2
I feel so sorry for Ben man... I know exactly how he feels!
Ben you will see in the end everything is going to be just fine! Like we say down here in PR, a la tercera la vencida!!!
Good luck!
Old Nov 10, 2011 | 09:26 AM
  #503
JARVEVO8's Avatar
haha, OK.
Is this leet's turbo?
Old Nov 10, 2011 | 09:32 AM
  #504
n2oiroc's Avatar
Nope, thats not a forged billet wheel.
Old Nov 10, 2011 | 09:33 AM
  #505
L888Apex's Avatar
I'm going to shoot myself if I end up driving that thing back to Ohio
Old Nov 10, 2011 | 09:49 AM
  #506
khmerpimpin's Avatar
Pull your water gun out, cause I'm sure it's going back.. It will be interesting to see what the cause was, and hopefully we get to see more efr results.
Old Nov 10, 2011 | 10:24 AM
  #507
leetEVO's Avatar
The car will be heading back to Buschur Racing within the next week or so. Here are some pics of the damaged 7670 for your viewing pleasure.
http://youtu.be/B7XQq5G7VCA
Old Nov 10, 2011 | 10:31 AM
  #508
Texas_Ace's Avatar
Wow, that thing got ate up.
Old Nov 10, 2011 | 11:24 AM
  #509
Beetspeed's Avatar
Looks like the exhaust wheel has more mechanical damage (broken-out parts of blades) then the compressor wheel.
Would it be logical to assume something went out the exhaust part of the engine, into the turbine, ate some turbine blades and that damage caused the bend shaft?
Something valve train related maybe broke off (valve guide piece or s/th like that?), further causing the engine failure later on with the 'new' turbo?
Old Nov 10, 2011 | 11:46 AM
  #510
R/TErnie's Avatar
I like the way you think.
