BEP S362 Dyno Results
Josh is making decent power on 12*, and btw his rings are still seating. This car will have no problem making 700whp in a few weeks.
btw, what oil do you run in your car?
Mikey
Thanks Josh, love you too brother. I am just messing with Josh. I have my reasons for not recommending meth to my customers. I have seen pumps fail, failsafes fail, foggers get stopped up, blocks split, pistons shatter, and uneven afrs across all 4 cylinders with meth. Cylinder #4 may be 11.8 but Cylinder #1 will be lean at 12.5+. E85 is not perfect but more consistant is you monitor the E content and run 93 through the car every couple of tanks to make sure the fuel system stays clean. No one can disagree with my comments. Facts are facts. If anyone wants to discuse more about the two we can go to pm.
Mikey
Mikey
Mikey
Mikey
Can't wait to see the car hit 700!
Mikey
Well we got the meth pump fixed/replaced and the cars flowing upwards of 1500cc and now the car loves life lol, I am showing the dyno from the first tune session to the last one both are 3rd gear pulls. It was even warmer out this time compaired to the last time when it was in the lower 30's. I say it each time the dyno reads 1psi higher then what I am running. I am only running 38 psi tappering to 33psi. The hotside is too small and the DP might need some work as well.
F2000Driver
For Sale - Cars For Sale
Nov 26, 2014 01:15 AM
I ran 1500cc when I had my meth kit. You will make loads of power!
