how much should i be making?
Old Mar 5, 2012 | 07:21 AM
03RRVIII's Avatar
Originally Posted by evoiao
something to do with the skunk TB and it registars onlt 93% due to the raduis of the wheel, it is opening 100% in WOT.
so this is what FFTech said and I do trust them.....they installed the skunk2 IM and Skunk2 TB.....
Im more concern about the low HP results, down by 15 to 25 seems like alot.....to miss out on....
That TPS issue is what's holding you back, and if they can't figure out a fix to that,, you should grab your wallet and run away. It's a simple fix just like what Tom said...
307whp on 22psi, sounds about right. And on E85 you'll probably looking @ 380 - 390whp. There is no way you can make 400whp with just those Mods you listed....
Old Mar 5, 2012 | 07:59 AM
evoiao's Avatar
fair enough whats next on the road to 400 hp.....
Old Mar 5, 2012 | 09:02 AM
Boostd4's Avatar
Upgrade to a stock frame turbo like a BBK or FP and you'll be well over 400whp on E85.
Old Mar 5, 2012 | 09:17 AM
03RRVIII's Avatar
To get 400whp on their Dyno, you'll need a test pipe (its not on your list) with a free flowing exhaust, some ARP headstuds, a stronger fuel pump than the walbro 255 or bigger injectors, a high pressure wastegate to hold better boost up top, and 30+ psi of boost....
Unless your car is one of those Factory Freaks! You might get to 400 or close, but will run out of fuel @ 6k rpm. LOL
Old Mar 5, 2012 | 02:12 PM
evoiao's Avatar
ok already have the apr studs and 255 fuel pump so Ill get larger injectors( i currently have 1000), and fftec will tune it to 29/30 psi on e85.....depending on the number of knocks (more the 3 knocks and they'll turn down the boost)
Old Mar 5, 2012 | 03:55 PM
swygar's Avatar
should be able to get 400whp on that setup, fairly easy.
Old Mar 5, 2012 | 05:29 PM
03RRVIII's Avatar
On Dynojet yes.
Old Mar 7, 2012 | 03:42 PM
evoiao's Avatar
what the hp changes for a mustang dyno vs. Dyno jet Dyno?
Old Mar 8, 2012 | 10:17 AM
4g63guy's Avatar
How much do u think id make on an 06 Mr with fp red coswoth m3 cars basic boltons stock block with 115k and e-85? Ball park?
Old Mar 8, 2012 | 10:18 AM
4g63guy's Avatar
Cams**
Boosted Tuning
Aug 5, 2016 08:12 AM
tscompusa
Mar 5, 2016 03:15 AM
Brianawd
Mar 2, 2016 08:10 PM
lopillo_evo
Feb 2, 2014 11:39 PM
Boosted Tuning
Oct 12, 2013 04:52 PM
