CBRD BBKB BB on 92 octane
Old Jun 21, 2012 | 05:31 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Nice numbers!
BBKB @ only 25psi? Interesting.
Old Jun 21, 2012 | 05:43 PM
STWHY?'s Avatar
Awesome man...Im a contractor out at Pearl working..Ill be here til August 30th,then ill be back in November till sometime in april or may...Id love to hook up with some of the local evo guys..But,i work a screwy schedule most of the time..Anyways,great numbers..And ill def like a ride when we can GTG..Take it easy..Justin
Old Jun 21, 2012 | 07:15 PM
SmurfZilla's Avatar
Originally Posted by AreSTG
hahaha. think of the headaches you would have avoided...
this was what i wanted to run on my build, but could never get a date for availability, so hence the BB Black.
Homie if I never blew my motor I would've avoided a lot of bs.
And I would def be buying one of these.
Old Jun 22, 2012 | 03:09 PM
Craig King's Avatar
Why is this interesting? Is it not normal to run 25psi ?
Old Jul 18, 2012 | 09:31 AM
Levar's Avatar
Veteran: Army
This is pretty good considering this was done on the stock block and 92-octane. That is an easy 500whp+ turbo on E85.
I do believe that the Driven Innovations intake manifold could be holding you back at those boost levels in the low-to-mid range. I believe one of the OEM-version intake manifolds (i.e. CBRE, MAP, etc.) would work out better.
Old Jul 18, 2012 | 08:23 PM
hifd's Avatar
I tried to find bolt ons that didn't affect spool too much, but I think you are right. I do have a MAP standard rod 2.4 with an AEM water meth kit waiting to be installed and will be increasing boost. Hopefully at greater boost the loss of spool will be offset by higher flow.
David.
Old Jul 18, 2012 | 10:14 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Chad has told me in the past that the BBK Full is the turbo you want to run if you're going to be under 30psi. BBK-B is ideal at ranges greater than 30psi.
Old Jul 18, 2012 | 10:20 PM
Levar's Avatar
Veteran: Army
Chad has told me in the past that the BBK Full is the turbo you want to run if you're going to be under 30psi. BBK-B is ideal at ranges greater than 30psi.:
This puts me in a tough position as I have some poor quality 91-octane and was only able to get 24PSI during tuning. On E85, I was at 30PSI+. I am set up for map switching.
Old Jul 18, 2012 | 10:32 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Originally Posted by Chad Block
The BBK Full is still my choice for 90% of our clients that want stock like response and excellent peak power- plus its biggest benefit is running the stock bearing package which doesn’t require special oils etc-
If you aren’t running over 30psi- the BBK full is stronger-
Normal psi range on pump gas would be 24-27 psi-
Much over thatyoull need E85 or race fuel to support it without detonation!
Old Jul 19, 2012 | 08:06 AM
Levar's Avatar
Veteran: Army
I am trying to contact the CBRD Team as they are on vacation.
Old Jul 23, 2012 | 09:54 AM
CBRD's Avatar
we are back-
busy busy with phone calls and emails!
cb
Old Jul 23, 2012 | 12:37 PM
4RETECH's Avatar
Really, that much power, LOL. Just kidding, I own one and always downplay how much power it really has.
Now I have to get my car on the dyno to see if all this is true. LOL
I've had the BBK-3B for 12,000 miles now. I love it.
Now if I would just get off my butt and get the headwork done to get the BBK-C
Great work as always Chad.
Nick
Old Jul 23, 2012 | 01:33 PM
CBRD's Avatar
LOL!
cb
94AWDcoupe
61
Jun 24, 2016 06:19 PM
hifd
Aug 8, 2013 11:04 AM
veilside prius
Feb 21, 2013 07:21 PM
stabiemcstabin
16
Oct 15, 2011 11:45 PM
CBRD
31
May 18, 2011 12:35 AM
