BR 2.3RPM, FP Black and issues.....
Kelfords ramp rates and centerlines dont seem to work as is, I know how they compare to other similar camshafts. Dave and I have noticed this (and commented) on it for the last few years. One thread was deleted for some reason, but the fact that remains is they are noisy...like detonation. They also make 20whp less on average because of the shape of the lobe.
Now the time has come to pick a 280/s3/m3 type cam and I'm back in the same dilemma.
Anyways,
I'm interested in seeing what this motor can do once the issues are resolved.
Is the 2.3RPM able to spin higher due to the lightweight billet crank, or is it additional magic?
i went 133.16mph on kelford 272 making me #6 fastest stock frame of this year.. i don't think the cams are that bad.
The gsc s3 i have in my car right now are much louder then the kelfords ever were "WOT".
price wise the kelfords cant compete with gsc though.. performance wise its a pretty level ground. in turn, gsc sells more. I am very happy with both brands though at the end of the day.
but on another note.. obviously David doesn't want neither cams in this car. he wants his BF 272 in here..Cant really blame a guy for wanting his brand of cams in the car that he knows very well vs others and knows what they are going to do performance wise. Same with the FMIC.
I am staying out of the debate, but i have nothing but good things to say about my BR Race FMIC and it fits fine on a evo 9 front bumper when its installed properly with his lower piping.
Tom,
Not disagreeing but adding what I have experienced-
The only time I have seen S3s be noisy in a car was with Supertech dual springs. Kiggly or GSC springs and they are fine.
Sobo, just stating what I have experienced. The Kelford 280/276 will make power but idle a little more radically than I like for the power they make. The S3 makes the same or more power and seems to be better behaved.
Tom,
Thanks for that information Aaron.
I pulled up some logs for reference. I run a Garrett core 24x12x3.5" shown below.
Here are what my logs show:
1st - 3rd gear run on the street at ~30psi and 92F ambient temps
Run duration: 6.7s
IAT Start Temp: 95F
IAT End Temp: 100F
3rd gear run on dyno at ~30psi and 92F outside temps (inside temps cooler)
Run duration: 7.2s
IAT Start Temp: 82F
IAT End Temp: 89F
Run duration: 6.7s
IAT Start Temp: 95F
IAT End Temp: 100F
Run duration: 7.2s
IAT Start Temp: 82F
IAT End Temp: 89F
l8r)
So if the FMIC is 5-6 years old, what are the odds that it's not working at peak performance anymore? IMO it's way too easy to read too much into this. I don't doubt that there will be power gains by going from a 5 year old IC to a newer, bigger IC. No need for everyone to sensationalize.
l8r)
l8r)
