BR 2.3RPM, FP Black and issues.....
I don't know what the inside of the fmic may look like but the car had catch cans on it 90% of its life. It could have some oil in it but seems like any major improvement in efficiency has more to do with the type of core or design tho..maybe their older cores were not so good?
Idk but that's why I sent the car to people who have their hands on more evos than Florida has sunshine.
Idk but that's why I sent the car to people who have their hands on more evos than Ohio has cardinals.
I tuned a 6262 Evo with an ams cooler. At the track start iat's were 100 and through the traps was 175. Car ran great 1/8 mile but terrible 1/4.... this was at 35psi. I have an ets 5" and I only see 120 on the same day. Intercooler design is everything! ets and Buschur coolers work.....
Kelfords ramp rates and centerlines dont seem to work as is, I know how they compare to other similar camshafts. Dave and I have noticed this (and commented) on it for the last few years. One thread was deleted for some reason, but the fact that remains is they are noisy...like detonation. They also make 20whp less on average because of the shape of the lobe.
This forum makes me scratch my head sometime. Emery swears by the Kelfords (Which i personally ran in my car with excellent results, tuned by him) and dislikes the GSC's; Everyone online seems to think the opposite!
Now the time has come to pick a 280/s3/m3 type cam and I'm back in the same dilemma.
Anyways,
I'm interested in seeing what this motor can do once the issues are resolved.
Is the 2.3RPM able to spin higher due to the lightweight billet crank, or is it additional magic?
Anyways,
I've seen a lot of GSC cams make good power.
The 2.3RPM spins higher rpm's because of the entire combination of parts and the build process.
I pulled up some logs for reference. I run a Garrett core 24x12x3.5" shown below.
Here are what my logs show:
1st - 3rd gear run on the street at ~30psi and 92F ambient temps
Run duration: 6.7s
IAT Start Temp: 95F
IAT End Temp: 100F
3rd gear run on dyno at ~30psi and 92F outside temps (inside temps cooler)
Run duration: 7.2s
IAT Start Temp: 82F
IAT End Temp: 89F
Run duration: 6.7s
IAT Start Temp: 95F
IAT End Temp: 100F
Run duration: 7.2s
IAT Start Temp: 82F
IAT End Temp: 89F
Now some random responses......
That original AMS FMIC's were too small and have had huge increases in IAT's since they were introduced, end of story.
I did a write up years ago, that can still be found here on the forums about cleaning out your intercoolers. If I remember right it was another time I tried to be helpful and just caught a bunch of **** from the internet experts who couldn't just use gasoline to clean it out and had to debate on the proper chemical composition of what was to be used....
The input on the cams.........boring, ridiculous and border line retarded. I dyno cams in engines/cars on a dyno, on the same day, back to back and collect data. The amount of cam swaps I've done is stupid. I've done 4-5 sets of cams in my car on the SAME DAY on the dyno to collect data. It's not a matter of "wanting" my cam in a car, it's a matter of what works best and if "my" cams didn't then I'd be having a new cam ground. I have cams that we "make" and cams from other companies I use if I want more PEAK power at high RPM than our BF272's, fact of the matter is NO cam I have ever run or tested has provided a better overall curve than our BF272 cam. You can take a look at the times, ET/MPH we've run, our customers have run and the many dyno sheets that we've posted showing the curves, the cams work.
We have the exhaust on this car sorted out and custom built as we were out of our tubing. The car is in the bay now for the new FMIC to be installed. Should hit the dyno soon.
Well question does the ait sensor read the same climb in temp when doing the same pull on the street. Any type of airflow to the filter, oe snorkel heat shield ducting from bumper to filter etc.....if I had to guess the turbo and manifold are creating excessive heat under the hood which can cause underhood temps ie ait temps to climb. Im sure you have an extra oe snorkel lyin around if not, id try that ...good luck.
A few days before this car was on we had the same combination on the dyno, it was the car I posted about, the EVO9 with 130 miles on it. That car has our Race FMIC on it, same turbo. Starting IAT's 51.8 degrees, ending were 55.4 degrees.
