HTA Green vs BBK Full
Old Nov 5, 2013 | 10:01 PM
  #61
Nimpoc's Avatar
Originally Posted by mrfred
The HTA Green and BBK are an interesting contrast. One thing I've come to appreciate with the Green is that the anti-surge cover is awesome for daily driving. Part-throttle studder is non-existent with this turbo whereas the stock turbo and the BBK both require a good DV to minimize it (but never completely eliminate it). The tradeoff is that the Green feels a little more lazy coming up to the powerband, but once inside the powerband, transient response is on-par with the BBK.
Did you ever think about trying the FP HTA cover for the BBK as a mitigation for the surge issue? There are a couple posts that suggest it does the trick. I've not seen any before / after testing though, just anecdotal prose.
Also interested in the boost levels where surging became an issue? I ask as I just purchased a BBK-Full with both covers and want to get an idea which to use for my low 20's application.
Old Nov 6, 2013 | 07:39 AM
  #62
mrfred's Avatar
I have anecdotal evidence that using the FP antisurge cover is bad for power with the BBK. One of my friend's had it on his setup, and despite his car having a solid set of bolt-ons and a sound motor, it wouldn't make more than about 430 whp at boost levels where I made 460+ whp. It would be interesting to see you try both.
I started see surge at the front end of the powerband when I started boosting past 28 psi. IIRC, it would surge a bit if I let the boost hit earlier than about 3800 rpm. What you see in the dyno pulls is the earliest I could let the power hit without getting surge.
Old Dec 31, 2014 | 08:26 PM
  #63
Htcg06's Avatar
Lets see what turbo lost longer gurantee fp
  #64
Htcg06's Avatar
The bbk is almost identical to fps turbos
Old Dec 31, 2014 | 08:27 PM
  #65
Htcg06's Avatar
Blouch knows it to after they got fp measurements
Mauricio Evo IV
11
Oct 31, 2017 12:10 AM
FreakEVO
Aug 5, 2016 10:21 AM
mrfred
Apr 26, 2016 05:05 AM
David Buschur
Sep 6, 2015 09:27 PM
mrfred
168
Jun 18, 2011 09:08 PM
