Switched to E85 and only Made an Extra 16WHP
Old Sep 10, 2013 | 08:44 AM
  #76
Randal's Avatar
Guest
Originally Posted by JohnBradley
Have you or AWD verified that the reluctor on the exhaust cam is installed correctly?
Not sure what that is but we checked the Timing and it was good.
Old Sep 10, 2013 | 08:49 AM
  #77
JohnBradley's Avatar
The piece that bolts to the back of the exhaust cam inside the sensor housing can get flipped 180* out and do all sorts of crazy things. Sometimes the car wont run, it wont make a pull in boost, or it drops 60whp. It can have proper cam timing and still have this side is not correct.
Old Sep 10, 2013 | 09:03 AM
  #78
Randal's Avatar
Guest
Wow I did not know that. Do you have a picture of where it is located? I am not sure where it bolts on to.
Old Sep 10, 2013 | 09:30 AM
  #79
Where the cam sensor plugs in on the driver side of the head. x3 10mm bolts in a triangular pattern on the cam sensor housing.
Old Sep 10, 2013 | 10:08 AM
  #80
Randal's Avatar
Guest
When I'm standing In front of my car the sensor that's plugged in the the front cam above the radiator hose?
Old Sep 10, 2013 | 10:58 AM
  #81
Fast_Freddie's Avatar
Veteran: Navy
Yes put the car at TDC, take the triangle plate off the end of the Cam sensor housing and take a look of the reluctor inside...
At TDC it should look like this
Old Sep 10, 2013 | 11:21 AM
  #82
^^^^ExActly.
Old Sep 10, 2013 | 11:31 AM
  #83
Randal's Avatar
Guest
Great!
How do I put it at TDC? Cranking till I land there ? Also it should look like that as what the position?
Old Sep 10, 2013 | 01:14 PM
  #84
Boosted Tuning's Avatar
Originally Posted by Randal
Great!
Either rock it in 3rd gear till engine gets all lined up or use a 1/2 breaker bar and rotate the crank.
Old Sep 10, 2013 | 01:29 PM
  #85
Randal's Avatar
Guest
But how do I know when it's at TDC? Do the cams have a mark that need to bet at the 12 o clock position?
Old Sep 10, 2013 | 01:51 PM
  #86
Correct, and then there is a mark on the crank pulley as well.
Old Sep 10, 2013 | 03:05 PM
  #87
Randal's Avatar
Guest
Ok so I adjusted the pulley until TDC. One cam was about a quarter to half an inch different from each other. For example the intake cam was perfectly upright while the exhaust mark was a little bit off to the left. Also see the Reluctor.
Old Sep 10, 2013 | 03:17 PM
  #88
Randal's Avatar
Guest
These are the cams at TDC
Old Sep 10, 2013 | 03:22 PM
  #89
90zcrex's Avatar
Make sure when you rotate the engine over to tdc, you rotate it clockwise and stop directly on the mark, don't rotate past the mark and back it up to the mark, it will put that slack in the belt like you have in the pics and your cams won't line up perfectly.
Old Sep 10, 2013 | 04:12 PM
  #90
Randal's Avatar
Guest
Is TDC the 0 mark in between the two 12's on the cam gear adjustments? Or is it the line engraved on the top of the cam gear on the Tooth? If it is the one engraved on the tooth I am attaching the pictures.
