91 octane evo 8 hx35 self tuned
Old Oct 2, 2013 | 09:01 AM
01sporty's Avatar
This is my evo 8
Speed density v7 tephra
2.4lr 4g64
Hx35 12cm
Tial q 50mm bov
Tial mvr 44mm
26psi on crap 91 octane
Gsc r2 cams(by far best stroker cams!!!)
Put down 469.8 hp 494.4 ft lbs torque
Old Oct 2, 2013 | 09:03 AM
01sporty's Avatar
Full boost 4200rpm torque is ridiculous
Old Oct 2, 2013 | 09:27 AM
deylag's Avatar
Wow definitely interested in seeing some pictures of your setup.
Are you using a custom manifold?
This peak power band is crazy. Its only got 1K-2K of peak power before it winds down. I wonder why that is?
Old Oct 2, 2013 | 10:01 AM
01sporty's Avatar
91 octane here sucks and to be honest it's not finished I'm runnin super low timing
Old Oct 2, 2013 | 10:03 AM
01sporty's Avatar
Only had 1 hour on the dyno needs more tuning I will post up a new graph in a couple days my clutch started to slip so I'm doing a qm twin
Old Oct 4, 2013 | 08:36 PM
rstchris's Avatar
Looks like the upper end needs more work. Seems like it has way more left in it up top.
You should try VD as the tune is currently, then fine tune it up top and see what VD says for gains.
Old Oct 5, 2013 | 03:46 AM
fillis's Avatar
This..
OP, what are you using to run a holset?
Old Oct 5, 2013 | 05:03 PM
rstchris's Avatar
Originally Posted by fillis
This..
Prob a t3 with that 12cm housing.
I think the old BEP housing for DSM was around .55ar
Bump for pics!
Old Oct 6, 2013 | 09:39 AM
Durtyballer01's Avatar
That's realllly gooood bro
Old Oct 6, 2013 | 09:40 AM
That's some good number man
Old Oct 7, 2013 | 02:54 AM
Levar's Avatar
Veteran: Army
I have always been a fan of what Holset turbos can do on a DSM. With an EVO, it should be even easier to make power and torque. That is pretty darn good for 91-octane.
Old Oct 7, 2013 | 03:17 AM
yrkesman's Avatar
What size wheels does that HX35 have? Have you tried any bigger turbine housing with it?
Old Oct 8, 2013 | 03:26 PM
Rpf1evolution's Avatar
looks good so far
Old Oct 9, 2013 | 05:49 AM
RWD4G63's Avatar
I take it you're using an open manifold and the stock turbine housing? Seven or Eight blade HX35?
HX35 has a 70x60mm turbine wheel designed for spool. The compressor wheels has various configurations, 7-blades are 54x78mm and 8-blades are 56x83mm, the 7-blade is best IMO.
Old Oct 11, 2013 | 09:30 AM
01sporty's Avatar
I will heroics posted and I will be working on the higher rpms soon just need to change my clutch out it started slipping bad
nikush
Oct 25, 2018 04:17 PM
boxerdropper
Dec 15, 2015 08:41 AM
Squid747
Aug 29, 2015 10:17 PM
cjcap
Dec 8, 2012 01:33 PM
3bar_dc2
Nov 22, 2010 03:48 PM
