Evo IX RS - Stock block / Stock cams / 6266 / E85 @ 32.7psi | 10.76 @ 136.17
#34
Well i finally got to take the car to the track! The Street Car Takeover was in town and i figure why not a better time to make some passes. It was down for 2 months from Nov-Jan getting a rebuilt trans with an evo 8 4th and 5th gear along with an exedy twin HD. Other than that, nothing power wise on the car has changed. It did do way better at the track then i expected it to do. Started off with some mediocre passes trying to get the new clutch figured out but ended up with many 10 second passes then ended up doing a 10.7@136 after i dropped the tire pressure down to 25 psi. This was done on Bridgestone Potenza RE760 245/45/17 street tires. Not bad for a stock longblock just shy of 103,000 miles.
Ive been waiting a long time to get back to the track. And im sure this is the last pass the stock motor will see being that me and Tom have been discussing a 2.0l LR build which should happen this summer hopefully.
Pics attached below
TSCOMPTUNED FTW!
Pics attached below
TSCOMPTUNED FTW!
Also 87F or whatever it was, doesn't help either. You should be very happy with your times. and ET. You improved just about every pass.
#37
Good job Morgan! 136 trap speed in a full weight RS is about a 650whp car. You didn't remove any interior or pieces of the car right?
#41
Thank you.
Good stuff.
It went 10.76 at 136.17 thats pretty good for street tires and his 60ft.
That mph can go 10.3-10.4 with a perfect pass and slicks though (for this vehicle) (or quicker).
Look at my car. I went 148.14 and only 10.26. (pathetic) Its a lot different once you are actually there. It is hard to ET a car. The mph for the most part comes naturally with the power, but even that is skewed a little based on driving & track conditions.
Definitely had street tires. I'll let Morgan confirm.
tscompusa
Sep 14, 2017 10:12 PM
tscompusa
Jan 28, 2015 04:43 PM
tscompusa
Aug 19, 2014 06:31 PM
tscompusa
Nov 26, 2013 05:01 PM
