Strange fuel issue - looking for ideas
Need some advice on a fuel issue I am having.. My current setup is as follows..
ID 2000's
Buschur DP 255's
-8AN Feed
Stock feed line in place of stock return line.
Stock fuel rail
Stock FPR
I have ruled out everything below.
- Fuel pumps both replaced x2 + new filters
- Inline fuel filter
- FPR
- Wideband Sensor
It only occurs after 28PSI; its leaning up towards the end of the pull.
Any ideas?
ID 2000's
Buschur DP 255's
-8AN Feed
Stock fuel rail
Stock FPR
- FPR
- Wideband Sensor
Any ideas?
I would say the second pump isn't activating but I doubt a single 255 could flow enough to reach the power level you got to before leaning out.
I'm guessing this is a problem that occurred on a car that was already tuned and running fine not in the process of being tuned?
Heres your fix $112 **** can those 255's buy a single stealth pump on sale from extreme psi make sure you do the rewire and your good for 780hp with a single pump.
https://www.evolutionm.net/forums/ve...fuel-pump.html
