EFR 9180 Break in tune 430whp 20psi
Old Nov 9, 2016, 11:11 AM
03Roush2's Avatar
Ok so this is just a break in tune. Not aggressive what so ever and just on waste gate boost.
Link to my build thread:
https://www.evolutionm.net/forums/pr...fr-9180-a.html
Break in miles, a few oil changes then E85 and tune
Old Nov 9, 2016, 12:00 PM
vmrevo9's Avatar
Should be a beast once fully tuned/broken in
Old Nov 9, 2016, 12:05 PM
lancerrally45's Avatar
Buddy has roughly the same turbo on a ten. He is around high 800s hp wise. Its a whole lot of turbo and the spool is instant at higher psi.
Old Nov 9, 2016, 12:17 PM
03Roush2's Avatar
Thats what Im hoping for. And I have a 1.45 hot side on deck
Old Nov 9, 2016, 12:41 PM
4b11slayer's Avatar
I wana hear those twin gates scream
Old Nov 11, 2016, 05:40 PM
evo8vz's Avatar
I wonder how this will work with a 2.3
heard 2.3 dont like more than 800 whp because wear becomes an issue
anyone enlighten me? I am tearing down a 2.3 to a 2.0 because of this.
Old Nov 11, 2016, 09:34 PM
Abacus's Avatar
100mm crank has more leverage and can start to flex . 700/800 seem to be a good stopping point for the big crank.
Old Nov 11, 2016, 10:02 PM
evo8vz's Avatar
I have two 2.3 and im tearing one down to a 2.0
The other I am thinking about running a magnus crank to leave at 2.2
Want to run a super 94 type of turbo and a super 99. The 2.3 isnt very good with these turbos im told?
Old Nov 12, 2016, 06:49 AM
Abacus's Avatar
PM sent.
To the OP, Nice build and looking forward to the results.
Old Nov 12, 2016, 10:15 AM
03Roush2's Avatar
So to combat the issues that you guys described. we went with a very light rotating setup.
Wiseco 10:5:1 HD2 pistons
Manley Billet Knife Edge Crank (Hopefully can handle 800+)
FFWD Aluminum Rods (465 grams) Manley "turbo tuff"-697 grams R+R alum rods-487 grams
Clearances on the block were left slightly looser to handle 45+psi. Everything was built for well over 1000hp.
The Roatting setup was balanced to 9500, as anyone will tell you thats very high for a 2.3 I will be shifting at 8500 max at the track 8k daily. This turbo is all in at about 4k so its plenty of turbo
Old Nov 12, 2016, 10:39 AM
evo8vz's Avatar
had a manley billet crank too, carillo rods and hd2 piston
sold it though
​​​​​​got oem crank and will order piston monday
Old Nov 12, 2016, 10:56 AM
03Roush2's Avatar
Originally Posted by Abacus
PM sent.
Did not receive a message.
Old Nov 12, 2016, 01:22 PM
Abacus's Avatar
Sorry , I had sent evo8vz a message so I didn't clutter your thread.
Running light rods is easier on the bearings and it should rev up quick. Keeping the rpm down will also keep piston speed in check. Looks like you put a lot of time and effort into your build. Nice work.
Old Nov 12, 2016, 01:29 PM
03Roush2's Avatar
I tried. Mostly a lot of money lol. But the FFWD even have a dowel pin to hold the bearings in place. Thanks for looking! I should have bette renumbers once I break it in, and put the 1.45 hot side on!
Old Feb 19, 2017, 05:50 PM
illusin's Avatar
Friend this year at SOCAL Mitsubishi Owners Day running a fully built 2.3 stroker with a super 94 put down 900+ hp and over 600 + ftlbs of torque. 2.3 can use either with no issues
Quick Reply: EFR 9180 Break in tune 430whp 20psi
