The little BBK full
Old Aug 26, 2019 | 09:18 AM
blackline's Avatar
5 Year Member
The little BBK full
This is my final results for my BBK Full.
Car: 2004 Evo 8
Mods:
  • Built 2.0(The normal, TT rods, pistons, crank)
  • Street ported Head
  • S2 Cams
  • Manley Springs/Retainers(I know, upgrading to GSC next year)
  • Ported IM with 70mm TB
  • FIC 1220cc low z Injectors
  • Bushur double pumper(2x 255)
  • Ported exhaust manifold
  • STM Open dump down pipw
  • Invidia test pipe
  • Megan catback
  • BBK Full(ported wastegate hole) with TS 22psi gate
  • Stock ecu with flex fuel, Tuned by Boosted Tuning
  • Jacks Tcase and gearbox
  • Sheps rear diff
I've had a **** ton off issues while tuning the car, from boost leaks to crazy boost creep...It's not high HP car but a fun street car.
pump 93 - 431hp/347tq
pump E74 - 481hp/365tq
Old Aug 26, 2019 | 09:32 AM
2006EvoIXer's Avatar
Congrats, looks like a fun street car!
Old Aug 26, 2019 | 02:21 PM
ctfpevoVIII's Avatar
Very solid #’s !! That’s impressive for that turbo, I run the BBK-3b. What boost did you run on your top line? Was that a maxed out run and then you dialed it back?
Old Aug 26, 2019 | 03:14 PM
Abacus's Avatar
400 ft lbs from 4000-7000!
Thats a fun street car.
Old Aug 26, 2019 | 03:44 PM
blackline's Avatar
5 Year Member
Thanks!
That was the final run, 30psi on all the runs. The middle and last are in 4th gear, first was 3rd gear.
Yes sir! Going to try it out on the autox next month
Old Jan 15, 2020 | 03:57 AM
ptitnicor's Avatar
Nice setup and results !
What's the problem with Manley springs/retainers ?
Old Jan 16, 2020 | 08:54 AM
blackline's Avatar
5 Year Member
based on the specs from manley these springs/retainers are rated for 30 psi, since I'm at the limit and don't want any float. I would like to upgrade to a set that is rated for more.
Old Aug 31, 2020 | 02:25 PM
Turtletron's Avatar
5 Year Member
I have a similar engine and yet my bbk full puffs down to 24/25 psi past 7000rpm...
Could an open dump or the porting really help that much?
Old Sep 2, 2020 | 12:31 PM
blackline's Avatar
5 Year Member
I'm not sure if the open dump/porting(ported to put boost creep in check) but I'm also using a 22psi turbo smart wastegate. Post you dyno graph and mod list.
tscompusa
Feb 13, 2017 05:20 PM
STLEVOIX
25
Nov 23, 2015 03:52 PM
tscompusa
Feb 26, 2015 05:01 PM
Ronnie Size
Nov 22, 2012 06:17 PM
Mike.p
Mar 11, 2010 06:09 PM
