Post exact weights of weight reduction you have done!
Old Oct 31, 2007 | 09:43 AM
  #181
dudical26's Avatar
Originally Posted by EvoIXMR
mine is benig built to be a track *****. I have airbag harnesses and all door wiring harnesses, sunroof harnesses, etc removed. So, yeah AC isnt that big a deal. It will have heat for now, but depending on hardcore I become, I may get rid of it next year.
I wish I had money, I would buy an Ariel Atom instead of building an Evo!
Man, I can't wait till you done, that think is gonna be light
Old Oct 31, 2007 | 10:11 AM
  #182
EvoIXMR's Avatar
I dunno about that, Dudical. I am trying to drop weight as much as I can. But, not dropping heat, blower and dash is probably a 100 pounds, you think? I heard most of the drag cars like the AMS weigh at 2900 pounds with the extreme weight reduction they have done - I wonder if I will be below 3100 lbs, I sure hope so!
Old Oct 31, 2007 | 10:30 AM
  #183
dudical26's Avatar
They also have a full cage (around 130lbs or more)
And I think they weigh less than that. I mean my car is just over 3000 with me in it and around 2 gal of gas.
Dash is very heavy, I wish I could take that out. If you really went all out, taking out dash and gutting EVERYTHING out of the doors, that would be right around 200lbs saved, crazy I know.
Old Nov 7, 2007 | 12:56 AM
  #184
medsheikh's Avatar
This is a very helpful thread, great contribution
Here is my situation:
My car is completely converted to a track car... It belongs to open class sprints & hill-climbs. it is completely stripped (except ac & abs) with engine modifications and a very heavy certified cage (110 pounds).
With full tank & no driver it now weighs 2,918 pounds. My target power to weight ratio per ton is 500. Its now at approx. 440.
In other words the car needs to weigh approx. 2,557 pounds or 361 pounds less
This might be impossible, but getting closer to the target figure will help.
Any advice?
Attached Thumbnails Post exact weights of weight reduction you have done!-septaat-009.jpg   Post exact weights of weight reduction you have done!-septaat-011.jpg   Post exact weights of weight reduction you have done!-img_0991.jpg
Old Nov 7, 2007 | 07:42 AM
  #185
dudical26's Avatar
Pull out the dash bar, AC, and all the wiring you don't need going to AC and even the wiring harness from the doors.
Do you have lexan windows?
Also, what about CF hood, trunk, roof, driveshaft?
They are pricey but light.
Old Nov 7, 2007 | 09:28 AM
  #186
KevinD's Avatar
Originally Posted by medsheikh
Any advice?
take the intercooler sprayer out. it weighs 10 pounds with water in it. i can see it in the picture
Old Nov 7, 2007 | 09:53 AM
  #187
EvoIXMR's Avatar
Dudical - see what I mean? medsheikh weighs 2900 pounds with a lot less than me such as carbon doors, JDM bumpers etc....I hope I can weigh in at 3000
Old Nov 7, 2007 | 11:02 AM
  #188
dudical26's Avatar
Yea but he has a 110lb cage, which more than cancels out the doors. That was also with a full tank of gas, which is around 100Lbs as well. I have no doubt you will be under 3000 without you and just over 3000 with you.
I am going to be at the track in a few weeks, my goal is to be 3000 with me and 2 gallons of gas, I'll let post up when I go on the scale there.
Old Nov 7, 2007 | 01:19 PM
  #189
EvoIXMR's Avatar
I will have an autopower roll bar, though!
Old Nov 7, 2007 | 01:50 PM
  #190
dudical26's Avatar
What is the weight on that?
Old Nov 7, 2007 | 02:18 PM
  #191
EvoIXMR's Avatar
need to find out probably order one here soon!
Old Nov 7, 2007 | 02:57 PM
  #192
dudical26's Avatar
Where do you live, KingKyle (hot lap motorsports) on this board sells them pretty cheap, at least he quoted me a good price. He is in NJ.
Old Nov 7, 2007 | 08:39 PM
  #193
EvoIXMR's Avatar
I am in Iowa aka BFE. KingKyle is the person I want to order from. I sent him a PM and waiting to hear back from him!
Old Nov 10, 2007 | 12:06 AM
  #194
medsheikh's Avatar
Thanks,
How much does the ac/heater with all the related components (ducting, wiring controls etc.) weigh? it was not clear in previous posts.
Windows are standard to be replaced with acrylic.
Stripped aluminum roof is light, but I hear that the cf hood is as heavy as standard. If not what brands do you recommend?
cf driveshaft is nice, but too expensive
Old Nov 10, 2007 | 07:28 AM
  #195
dudical26's Avatar
Thanks,
The AC components under the hood weigh 30lbs. The heat and all other related components inside the dashboard weigh around 15lbs
the CF roof is 10lbs, a steel roof is 26lbs. I think the aluminum roof is around 18lbs.
Stock hood is 18.5 lbs, Robi Spec sells a hood and trunk made by "downforce composits" His hood weighs 11lbs
Stock trunk is 22.5lbs, his Downforce composites trunk is 7lbs.
He charges around $750 for each piece.
