Post exact weights of weight reduction you have done!
Old Dec 15, 2011 | 09:06 AM
  #556
boomn29's Avatar
Originally Posted by boomn29
Latest update - 3191 wet.
I'd guess about 3021 w/o driver (aka dry).
Winter 2012 pre-diet stats:
3182 track weight.
That's with me on the scales and includes a 60lb rollbar. So it's close to 3000 dry. Minus me and the rollbar - estimated 2940 lbs.
Now onto the winter 2012 diet. Here's a pic of misc dash parts, a-pillar plastic, etc (not the dash itself) mostly plastic but a few brackets - 12lbs. Note this does not include any screws or bolts! Some of this will go back in:
More gutting in progress. I'm thinking about taking out the window glass while at the track and putting it back in during transport (open trailer). Anyone have a writeup for that, please lemme know!
Stay tuned for updates and more weights...
A list of items specifically removed and NOT going back in. I'll try to get a specific weight on this stuff:
  • Both tweeters in the a-pillars
  • Driver's door speaker (passenger yet to come)
  • Passenger side airbag module (airbag had already deployed waaaay back)
  • Cutting more sound deadening underneath the dash, next to the firewall/windshield base.
Old Dec 16, 2011 | 11:17 AM
  #557
Evolution IVGSR's Avatar
There is a local guy here that his Drag Evo down to some low low weight. 1906lbs car with everything on and in the car except for the Seat and driver.
Old Dec 16, 2011 | 12:41 PM
  #558
Fairclough's Avatar
I have driver's seat in there Dallin!
It's 1880 now, and still losing weight.
Old Dec 18, 2011 | 06:18 AM
  #559
sleeper04's Avatar
dayum .....im just trying to get mine to 2900 race weight this year
Old Dec 18, 2011 | 07:51 PM
  #560
Kidloco51's Avatar
I am gonna remove my front glass aswell. It is part of my winter project too. I will holler once I come up with my idea.
Old Dec 19, 2011 | 11:28 AM
  #561
AWD96's Avatar
This thread is awesome.
Old Dec 20, 2011 | 06:14 AM
  #562
S13 Curtis's Avatar
I weighed in at 3180 dry. Mine is an SSL car also. not sure what more i can do with out compromising the stock interior look.
Old Dec 20, 2011 | 06:35 AM
  #563
boomn29's Avatar
Here's some misc weights:
  • 15lbs - Stock plastic dash - Just the plastic; everything removed that I could
  • 5lbs - driver's side doorskin; just the plastic 'skin'
  • 5lbs - Passenger side airbag module (w/o airbag)
Old Dec 20, 2011 | 09:06 AM
  #564
jerdeitzel's Avatar
Nathan, it looks like your on your way to race car mode!
Is this for TTS or ST2? I'm making a move to Milwaukee and will most likely try and run NASA midwest events this year.
Old Dec 20, 2011 | 01:55 PM
  #565
boomn29's Avatar
Possibly either or both.
I pulled the dash out of the car thinking I might be caging it. But regardless, I want to pull as much weight as I can off the front of the car. Like 63% weight up front...
Old Dec 21, 2011 | 07:55 AM
  #566
RLLN247's Avatar
Did you get a chance to weigh the door speakers yet . I went to pull the tweeters out they didnt weigh anything. So before i take the door skin off I would like to know how much the speakers weigh.
3182 track weight.
Old Dec 21, 2011 | 08:30 AM
  #567
jerdeitzel's Avatar
Stock radio-4lbs
Stock speakers- 1lb each
Old Dec 21, 2011 | 07:59 PM
  #568
XcreatonX's Avatar
I would also like to get more weight out of the front. My rear end is light as it is and rotates nicely.
I want to get under 2800 for my car with full int.
Old Dec 22, 2011 | 06:54 AM
  #569
mrboost05's Avatar
Originally Posted by B.J.@ToxicFab
18 lbs is a ton for a clutch, holy crap, didn't know that...Currently I am rocking an ACT 6 puck & fidanza flywheel...I've been looking into the QM when I do my 5 spd swap...Good to know...
its alot compared to a single disc setup i think my exedy tripple was 28lbsif u get the carbon carbon its lighter because the flywheel is drilled out but the comp twins and Qm twins are alot lighter they are pretty harsh to drive and make a ton of noise tho.
Old Dec 22, 2011 | 01:19 PM
  #570
boomn29's Avatar
Stock radio-4lbs
Like jerdeitzel noted; there's not a lot of weight in the 4 speakers up front (2 tweeters in a-pillar). The doorskin pops off easy enough to yank out the speaker and you can pop the door skin back on.
If you go to work cutting out the thick sound deadening under and around the dash, you'll find more weight than with the speakers. I doubt you wanna cut/gut the door but that's where most people are finding the door weight savings, including the drilling the welds for the side crash beams.
