Viper 5900 Alarm LED Status issue
Old Mar 3, 2007 | 10:01 PM
evo_shibby's Avatar
I just installed my viper 5900 alarm.
The LED light keeps flashing whether the car is armed or not. It's pretty annoying as it keeps flashing.
Does anyone know how to disable the LED Status light when the alarm is disarmed? I'd like it to only flash when the alarm is armed. I've looked over the wiring and everything is where it should be, I'm looking at the install menubut can't really find anything on how to program it. Any help here?
Old Mar 4, 2007 | 12:33 AM
evo_shibby's Avatar
awesome think i found the solution. i'll try it in the morning.
Old Mar 4, 2007 | 09:04 AM
ntwaddel's Avatar
it keeps flashing if something has triggered a sensor, until the alarm is reset with the ignition on power wire.
Old Mar 4, 2007 | 10:28 AM
evo_shibby's Avatar
**** it didnt work. led still keeps flashing.
how do i go about resetting the alarm?
Old Mar 4, 2007 | 11:04 AM
evo_shibby's Avatar
ah fixed it.
Old Mar 4, 2007 | 11:17 AM
Dennis F's Avatar
Originally Posted by evo_shibby
ah fixed it.
What did you do?
Old Mar 4, 2007 | 12:54 PM
evo_shibby's Avatar
reset the alarm. the guy was right, something triggerred it so i had to clear the alarm history. i just unplugged the battery.
Old Mar 4, 2007 | 01:51 PM
ntwaddel's Avatar
well you dont want to have to unplug your battery each time your car is bumped or the alarm is set off. It sounds like the ignition wire is not connected
Old Mar 7, 2007 | 12:54 PM
evo_shibby's Avatar
interesting, so technically everytime the alarm is triggered, then disarmed and started the light should reset?
Old Mar 7, 2007 | 01:04 PM
kreionic's Avatar
Yes if it was triggered and you turned the alarm off the led will blink accorinding to what sensor was triggered. If it blinks once waits 3 seconds blinks once again its zone 1 (trunk) 2 flashes zone 2 and so on so on untill the car is started and then it resets
Old Mar 7, 2007 | 07:17 PM
evo_shibby's Avatar
ok i called the shop.
since i have an hks turbo timer, the ignition wire wasnt connected and in order fort he TT to work it has to be that way. so what they did was install a switch for me. so if i want to reset the light, turn the car on and flip the switch back and forth and it's gone.
boostedteg99
Jul 10, 2009 12:58 AM
chaquita
Feb 9, 2009 12:07 AM
iel322
Jun 1, 2008 07:56 AM
IMPORTIMAGE
May 1, 2008 07:54 AM
james781
Dec 7, 2006 07:04 PM
