ems and python
Old Dec 29, 2007 | 10:31 PM
amscrazy's Avatar
ems and python
will the python security/remote start work with my ems? it takes a while to crank, will teh remote start just crank until it starts or wat?
Thanks
Old Dec 30, 2007 | 11:25 AM
NoTec's Avatar
The remote start should crank until it recognizes a valid tach signal. So if it was properly connected before, you shouldn't have any problems now.
Old Dec 31, 2007 | 03:34 PM
mymigi's Avatar
i don't believe you had any problems, and if the tach signal doesn't pick up then you can always go with voltage sensing and program the crank time. all you have to do is time your crank and program the remote starter to the same time or a bit more.
BTW, which EMS do you have? AEM?
AEM would probably take 5 cranks which would time to about 3 seconds.
Old Dec 31, 2007 | 11:44 PM
amscrazy's Avatar
i do have the aem
Old Jan 4, 2008 | 05:03 AM
mymigi's Avatar
sorry for the late reply but you can set the crank time. I would set the vehicle to voltage sensing and set the crank time to about 3 seconds. That should give the system enough time to crank over and start. Keep in mind, during the colder months, crank time may or may not be longer....i have never really tried one on an AEM but it shouldn't be different.
Old Jan 16, 2008 | 02:23 PM
MRCole's Avatar
Do it the right way and go with tach sense. Voltage is nice if you are lazy and don't want to remove the cluster or hit an injector.
Difference is, voltage cranks for a programmed ammount of time, IE 3 seconds.
Tach sense, cranks till it starts. Just be careful if your car is heavily modded and won't crank over if you don't prime the car before you start, otherwise it will keep cranking.
Old Jan 16, 2008 | 02:27 PM
thatdudety's Avatar
i got a python securtity system just need to find time to install it
WarmMilk
Feb 5, 2014 06:29 PM
akemi27
May 6, 2012 09:26 AM
spoolinx
Jan 25, 2010 07:44 AM
Sofla GTS
Apr 18, 2008 08:00 PM
Celica2EVO
Oct 17, 2007 07:18 AM
