Head Unit Installation Problem....Please Help!!!
Old Jul 1, 2008 | 09:47 AM
BlackTypeS's Avatar
Ok well I have a bit of a problem...I have an Alpine head unit I am trying to put into my car...I have a 05' SSL...so I was reading threads on here about buying the harness for the head unit because I thought it was "plug and play" but I took out the stock radio, and the harness connectors do not fit into my Alpine head unit. The model number is CDA - 9856 if that helps...please instruct me on what to do from here because I am totally lost.
Thank you in advance!
Old Jul 1, 2008 | 10:03 AM
BlackTypeS's Avatar
bump
Old Jul 1, 2008 | 10:08 AM
06ravenmr's Avatar
u need a harness adapter to plugh the alpine harness into the stock harness. go to any car audio store and they will put u in the right direction
Old Jul 1, 2008 | 12:36 PM
BlackTypeS's Avatar
I already bought the harness now I need a harness adaptor?
Old Jul 1, 2008 | 02:50 PM
biggie5252's Avatar
There's a harness that comes with the Alpine that has a black plug on one end and bare ended wires coming out of it. This plugs into the back of the Alpine radio. The adapter is a seperate plug that also has bare ended wires coming out of it, but it plugs into the plug(s) in the car that were unplugged from the stock radio. You wire (preferably solder) the bare ended wires from each plug together, usually color matching, but depends on the application, plug the black plug to the Alpine, and the other plug(s) to your car, put it all back together, and there you go.
Old Jul 1, 2008 | 04:52 PM
06ravenmr's Avatar
^^^ exactly what he said
Old Jul 1, 2008 | 05:27 PM
BlackTypeS's Avatar
ok i think i got the idea..now the only problem is soldering ( i have no experience or tools to do it). Is there any other way/method around it like crimping the wires or is that something totally different?
Old Jul 1, 2008 | 06:07 PM
biggie5252's Avatar
You can get butt connectors (the little red ones) and crimp them instead of soldering. Soldering is a better more durable connection. Don't get the cheap crimpers from Walmart. Go to home depot or similar and get some decent Kline's (sp?). They are only crimpers and are the best ever until you get up into the 4ga range.
SHhhhh's Avatar
Old Jul 1, 2008 | 06:21 PM
biggie5252's Avatar
Here's what I was talking about.
Old Jul 6, 2008 | 12:20 PM
BlackTypeS's Avatar
ok new problem...whats with splicing the wires...i stripped them with the wire cutters and i have the butt connectors but how do they connect? Do you have to squeeze them somehow with a pair of pliers? Because I also tried this and had no success
Old Jul 6, 2008 | 01:05 PM
biggie5252's Avatar
Yes. Twist the exposed ends of the wires and stick them into the hole on the butt connector. Crimp the connector about a third of the way up the connector (about halfway up the end of the wire) with the crimpers that have been mentioned above.
Old Jul 7, 2008 | 11:58 AM
SRTRaceR04's Avatar
You know Circuit City sells plug and play kits right?? No splicing, soldering, etc.
Old Jul 8, 2008 | 02:25 PM
supercaL's Avatar
Originally Posted by SHhhhh
sweeeet haha
PlastikSeraph
Feb 26, 2012 11:03 AM
D1no
Jan 17, 2010 02:41 PM
Draoz4
Nov 19, 2009 10:02 PM
CoolDog
18
Jun 26, 2008 09:52 AM
Q@EvoPowerMods
Dec 25, 2007 05:03 AM
