breake lights out
Old Sep 30, 2009 | 01:31 AM
wasabisnooter's Avatar
breake lights out
My brakes lights are out. We checked fuses and bulbs and everything is good. What would be the next thing to check?
Old Oct 6, 2009 | 12:00 AM
divine_evo's Avatar
check to see if the brakes are pushing on the switch that turns on the brake lights. When the brake pedal is pushed there is a rubber rod that pushes on the switch. I haven't confirmed if this is the way Evos turn on their brake lights but i've seen it on all toyota's i've worked on.
Old Oct 6, 2009 | 05:12 PM
thanks bro, i'll check it out
Old Oct 10, 2009 | 02:33 PM
eXtreme-Speed's Avatar
If you have a volt meter have some one sit in the car and hit the brakes then use the meter on the brake light bulb connectors. If there is voltage then you know everything else is working, if not just go along with post above. Good Luck
Corton520
Sep 16, 2009 07:56 AM
XEVOX08
Jul 6, 2009 05:35 PM
Joho22
Mar 18, 2007 11:28 AM
U8THIS
Mar 5, 2004 07:42 PM
TaiwanEvo
Jul 25, 2003 02:52 PM
