stripped bolt issue!
Old Oct 31, 2010 | 06:47 AM
flyingscot's Avatar
hi all,hopefully someone can help me,i had some front end damage at the track but heres my issue,im not sure how the bolt got stripped but there are three bolts that hold the lower c member between the radiator support and the sub frame,two at the front and one rearward,the one at the back got stripped somehow,the member got bent pretty badly and was not salvagable so its possible the bolt got bent slightly therefore stripping it when i removed it,without removing the subframe is there a way i can get that sorted,i got a new bolt from mitsu but it still wont go in easily,dont want to strip that on too
Old Nov 1, 2010 | 06:43 PM
TJSAP00's Avatar
Drill and re-tap it man.
Old Nov 1, 2010 | 09:10 PM
flyingscot's Avatar
thanks for the reply,wondered if anyone has had a similar problem
Old Nov 1, 2010 | 09:18 PM
TJSAP00's Avatar
No problem man.. Some people may have Im not sure, but best bet would be to drill it out get a tap and re thread it. Google or youtube some videos for like a how-to if you need it. Goodluck.
Old Nov 3, 2010 | 12:38 PM
atxMR's Avatar
If you have the proper size tap then Often times you can "clean" the threads up with the tap and reuse the original bolt size. I would try just running it through the threads first. If you drill it you'll definitely have to go up in size on the bolt.
Old Nov 3, 2010 | 07:06 PM
flyingscot's Avatar
thanks guys,wanted to ask before i went ahead,talked to mueller ,he recommended tapping with 1/2"std fine pitch,prolly do that,thanks for the replies
Old Nov 3, 2010 | 07:31 PM
kekek's Avatar
You do realize that every fastener on the car is metric right? Measure the fastener and order a proper rethread tap from mcmaster.com.
Old Nov 3, 2010 | 08:24 PM
flyingscot's Avatar
yeah i know but if its really stripped out bad then going with a slightly larger pitch might work,im gonna try the oem pitch first,for that bolt its 1.25
Old Nov 4, 2010 | 06:52 PM
kekek's Avatar
If you need to go bigger looking into a helical insert (helicoil is one brand). They typically sell kits and it's very easy to install.
Old Nov 7, 2010 | 06:29 AM
flyingscot's Avatar
thank you,i know of these and waying up my options,i also know of a few road racers that run a solid rear engine mount and eliminate the lower mount and c member completely,having trouble finding info on that though
k0lok0yboi
11
May 14, 2016 06:00 AM
kyoo
Jul 30, 2015 10:41 PM
apiazza2010
Sep 6, 2012 08:51 PM
jvlazzar
10
Jun 14, 2009 11:22 AM
thomas_herrera
May 24, 2005 06:33 AM
