Ignition problem
Old Sep 15, 2011 | 03:03 PM
chrisff521's Avatar
Ignition problem
Im having a problem where when i turn on my ignition the cel starts flickering and it wont let me start the car and sometimes fuel starts pumping into the motor even when not cranking.
I noticed that when i turn the key on the car is supposed make mutliple clicks from some relay im guessing in the engine bay. Whenever i do not hear that clicking, the cel lighg doesnt appear or starts flickering and the car wont start. it cranks but no start. I was thinking maybe a relay is getting stuck or something.I have to keep turning my key on and off until the cel stays solid and then it starts.
Im so stumped on this and idk what it is. I was driving the other day and the car just died while i was on the highway because of this. But most of thr time it only affects the startup.
Old Sep 15, 2011 | 07:35 PM
chrisff521's Avatar
Is there a relay or something that switches on the ecu. I feel like its not being turned on it something.
Old Sep 16, 2011 | 09:22 AM
chrisff521's Avatar
Bump....
Old Sep 23, 2011 | 07:42 PM
barneyb's Avatar
Is there a code being set in the ECU?
Old Sep 24, 2011 | 12:47 AM
chrisff521's Avatar
Well i have a jdm evo 5 motor in there so i have codes for thr crank and cam sensor. Would thr crank sensor possibly cause the cel not to appear. I ordered a new one today online and im going to see if that helps.
Old Sep 24, 2011 | 09:45 PM
barneyb's Avatar
Your complaint sounds more like the cam sensor is bad.
Old Sep 25, 2011 | 11:04 AM
chrisff521's Avatar
But what could cause the ecu to randomly disconnect from the car or to start making the lignt flicker and the rpm needle to bounce.
Old Nov 10, 2011 | 07:22 AM
tony gibson's Avatar
Any luck?
Old Nov 22, 2011 | 10:57 AM
chrisff521's Avatar
Yea it was the crank sensor. I changed that and never had the problem again. But it may have been because i have a evo 5 motor in my 8 and the sensors are different.
XinnKoda
Lancer Troubleshooting
Feb 1, 2016 08:58 AM
Roen
11
Oct 25, 2014 09:53 PM
kd5byb
Sep 7, 2013 05:44 AM
NICOJONES
Aug 2, 2013 01:13 PM
wazzelby
Sep 9, 2012 07:47 PM
