Radio / clock / rear wiper.
Old May 19, 2014 | 06:54 AM
True Blue's Avatar
Did a search, seems a few of us have had this issue before, but no one seemed to finish the threads with a solution.
https://www.evolutionm.net/forums/ev...d-working.html
https://www.evolutionm.net/forums/ev...need-help.html
https://www.evolutionm.net/forums/ev...per-relay.html
Kick panel has been pulled, no corrosion present, I dielectric greased all of the connectors anyway. My body grommet has been siliconed. Fuses and relays are all fine, I replaced the 10A in the yellow "box" just to be certain. No dice.
My next location is pulling the radio, mine is factory. What should I be checking for back there, aside from loose wiring?
Old Jul 25, 2014 | 06:15 AM
True Blue's Avatar
Bump.
Old Sep 1, 2014 | 05:31 PM
DarkEvoSe's Avatar
did you ever figure out why the rear wiper wasn't working? my clock and radio are fine but the other day the rear wiper just stopped working and I don't know why
Old Sep 25, 2014 | 01:22 PM
egis's Avatar
Remove coin drawer on lower left side of the dash.youll see fuse block.bottom right is empty spot with no fuse in it. I put fuse in that spot and all came back like nothin happened.
Old Nov 11, 2014 | 06:04 AM
True Blue's Avatar
Wow, I had lost all hope in this thread. The car's been parked but I'm getting it back to a ready state for wintertime.
Add a fuse to that location? What size fuse did you toss in?
Old Nov 11, 2014 | 06:08 AM
True Blue's Avatar
I'm wondering if the factory radio died and took all of the related items on its wire branch (wiper & radio) with it. Wouldn't mind putting an aftermarket radio in there but I'm stumped on if this will actually fix the issue.
Old Nov 14, 2014 | 05:34 AM
True Blue's Avatar
Added the fuse to the "radio" location in the passenger fuse block under the dash.
Lightsaber
Feb 16, 2018 05:17 PM
Royal Evo
Mar 17, 2016 11:57 AM
06MREvo
11
Feb 3, 2015 07:00 PM
GALANTZILLA
Nov 17, 2013 01:25 PM
SpardaVR4
Jun 11, 2012 05:31 AM
