Rockford radio help
Old Apr 24, 2020 | 04:05 PM
hawkj48's Avatar
Rockford radio help
Ok so I have a 2014 with the Rockford non nav radio. The sound was cutting out off and on for a few weeks and now I have nothing. I’ve checked the fuses already. I even took apart the amp to see if anything was fried on the board and still nothing. I even tried running the ext. device connection on the dealer screen and said amp was ok. After all that I realized that I couldn’t get a response on the screen if I adjusted the sound or the bass or the fader. Has anyone else had the issue is it a bad radio, amp or a wiring issue. I have a hour ride to work every day and can’t take the silence.
Old Apr 25, 2020 | 05:08 PM
Biggiesacks's Avatar
If the amps ok then that just leaves the deck. Guess its time to upgrade to something aftermarket. If you want to verify its the deck though you can get an integration/install kit for an aftermarket deck and try feeding in a signal to the amp to make sure your getting audio out of the speakers. If you don't want to DIY it you could just take it to a stereo shop and let them figure out what you need to get your tunes back.
Old Apr 26, 2020 | 09:30 AM
hawkj48's Avatar
Ok so I changed the deck out and got the same result. Is there anything that would override my sound control. Now I’m assuming it has to be a short somewhere
Old Apr 26, 2020 | 12:10 PM
hawkj48's Avatar
After messing around a little more I unplugged the smaller bundle of wire from the head. It finally let me make adjustments on my screen. Of coarse still no sound because amp is in that bundle to. So maybe it’s the hand free stuff. Could I cut the wires for it. And if I can which ones do I cut
AL.Gargett
Jan 11, 2019 07:31 AM
rosie09gts
Lancer Troubleshooting
Nov 27, 2012 05:35 AM
gray9evo
Apr 30, 2012 07:39 AM
EVO196
Feb 5, 2011 06:53 AM
Khoranic
11
Apr 23, 2009 08:34 PM
