Loss of boost
Old Oct 15, 2004 | 10:57 AM
showoff's Avatar
Loss of boost
My mods are Helix catback, downpipe, turbo xs hp mbc, and boost gauge. I installed the downpipe a few weeks back and everything seemed fine until the other day. I was running 21 lbs of boost before that and then all of a sudden my max boost is only 17. I check all the pipings and hoses 3 times and eveything seems fine. What could it be?
Old Oct 15, 2004 | 01:05 PM
showoff's Avatar
anyone?
Old Oct 15, 2004 | 01:08 PM
blackevoVII's Avatar
Fuel Cut? Any Surging? Stock Bov(maybe leaking?) all hoses and pipes are tight? or did you just check them?
Old Oct 15, 2004 | 01:17 PM
Stinkapuss's Avatar
Check the clamp that connects to the bov to the maf pipe.
Old Oct 15, 2004 | 01:24 PM
showoff's Avatar
I went so far as removing all the pipings, hoses, intake box, boost gauge, stock bov, and putting them back together. I also checked the exhaust system for leaks and its fine. How can you tell if the bov is leaking? I have an autometer boost gauge if that helps. You think the gauge could be broken?
Old Dec 17, 2004 | 01:00 PM
Ztypestock8's Avatar
i got the same problem. I'm only boosting about 15-18psi after tappering from 20-21 psi. It most deffinitly could be from youre bov leaking boost. I thought my turbo back was leaking but its deffinitly the bov. Do you have an "intake"?
Old Dec 17, 2004 | 03:26 PM
Nad1370's Avatar
Most possible cause would be your Blow-off valve.
It also could be your wastegate sticking open just a bit.
Gallagher444
Aug 10, 2015 09:53 AM
evoid
Jul 26, 2011 09:14 AM
black_beauty
10
Jun 1, 2010 06:51 AM
EvoIXMR
Oct 5, 2008 08:36 PM
EVO MR FU
Jun 14, 2005 05:05 AM
