Removing AC from my EVO
Old Oct 25, 2004 | 08:48 AM
Az3ar's Avatar
AC part number (smaller built) is mn-158795 only $54.
Old Oct 26, 2004 | 02:18 AM
simevo's Avatar
How did you lose 300lb of the Evo.
Ti Exhaust with DP : -40lb
Small battery : -20lb
CF hood : -10lb
CF trunk : -10lb
Light weight brake rotors : -40lb
Light weight wheels : -40lb
Strip interior : -60lb
This is what I estimate. It might be less though.
Old Oct 26, 2004 | 11:12 AM
Jamie@WORKS's Avatar
WORKS will be offering an A/C eliminator belt as part of our WRP. Look for it in the very near future
Old Jan 28, 2005 | 11:16 AM
EVOTEXAS's Avatar
What length belt would you want to remove the AC and have a crank pulley? Does it make sense to just add both lengths shortened together to come up with a total?
Old Jan 28, 2005 | 11:32 AM
MIevo8MR's Avatar
How about the complete HVAC system, including the actual HVAC inside the vehicle? I work for a HVAC supplier to one of the big 3 and i know that an HVAC can weight anywhere between 10-20lbs. while all the under hood components range anywhere from 15-20lbs.
Old Jan 28, 2005 | 04:04 PM
DynoFlash's Avatar
Guys - no need for any special belts - its a GATES # KO60578
Old Jan 28, 2005 | 04:05 PM
EVOTEXAS's Avatar
That fits when you have a crank pulley and skip the AC?
Old Feb 8, 2005 | 04:31 PM
Az3ar's Avatar
Ok I am removing my AC as I type and it's a mess ... I am taking the turbo kit off because my DP is touching my Koyo radiator and some welding and fabrication is needed. I will post some pics later on tonight but so far I have coolant all over my garage and things don’t look nice ...
stay tuned
Old Feb 8, 2005 | 06:40 PM
Az3ar's Avatar
ok guys the AC is out and pics are coming... Few things though. I have 2 sensors as you can see in the pics what’s going to happened to these?? will my engine check light come on and if so what code will I expect??
Attached Thumbnails Removing AC from my EVO-122-2247_img.jpg   Removing AC from my EVO-122-2248_img.jpg   Removing AC from my EVO-122-2249_img.jpg   Removing AC from my EVO-122-2250_img.jpg
Old Feb 8, 2005 | 07:27 PM
Joe250's Avatar
Relax
No worries. Just zip tie them out of harm's way. Won't set off any idiot lights.
Joe
Old Feb 8, 2005 | 07:41 PM
Az3ar's Avatar
Joe
nice man, You are the best...
Old Feb 8, 2005 | 07:46 PM
2k4EvoVIII's Avatar
The first plug with green insert is the A/C Clutch connector switch which when you hit the button in the car it sends a signal to the compressor to turn on. The second connection with the brown plug is the High/Low Pressure Switch. Which basically regulats how much coolant passes to the compressor which regulates how cold the air is when it enters the car.
You shouldnt have any problems with the check engine light coming on. I know for a fact that the green plug wont cause any problems. The High Low switch shouldnt cause a light either but i have the ohm settings so if it does you can install a resistor in the plug to fake the ecu into thinking everything is ok.
Chris
Old Aug 20, 2007 | 06:06 AM
justchil's Avatar
Old thread but I dugg it up on a search. Hard to find what belt you need exactly... the # dynoflash posted doesnt work. MN158795 comes up and I'm assuming it's the RS belt. I think there are 2 RS belts... one that would be too big and the other that might fit. Thread on this here: https://www.evolutionm.net/forums/sh...d.php?t=290235
I'm just trying to get the darn belt ordered... one that fits lol. 03 EVO8 a/c removed.
usnevo8
Aug 24, 2019 03:05 PM
bnr34rb26dett
Oct 7, 2012 08:17 PM
Evofletch
Aug 8, 2011 09:18 PM
Brokenevo
Apr 18, 2010 07:32 PM
Mr. Boost
Nov 11, 2006 04:20 PM
