finish the 3071R install
Old Oct 31, 2004 | 08:58 PM
  #46
Quickshift's Avatar
Sorry evolife04 , if you have any problems pm. I didnt mean to go off topic with your post. But like I said anything just send me a pm I am more than glad to help.
Old Oct 31, 2004 | 09:05 PM
  #47
Az3ar's Avatar
Originally Posted by bolsen
trolls
tell me about it... Alex is good at doing this
Old Oct 31, 2004 | 09:09 PM
  #48
IE Evo's Avatar
Originally Posted by Az3ar
I don’t know why some members ( ted B, IE and ALEX ALEx)on these forums keep following the 3071 threads all over. The guy was asking clearly about installing the kit and if we (3071 owners) have one and what we think. I don’t know why you guys have to follow (I can point the 3 of you to every 3071 thread especially for ATP) and give bad comments and start a flame war. The truth is many many people are choosing this kit for the price and for the stealth reliable stock look and of course low cost. I see saving $2k and loosing 20WHP is a great deal. When I hit 430WHP with all supporting modes and IE hits 450 I see no reason to spend so much extra cash for 20 or even 30 WHP and loose some stealth hidden look NOTE: my car was completely inspected in VA here last week and they did not even know I have a bigger turbo. Many have owned this kit and they love it because it was made for a purpose and it served its purpose well.
About numbers I still have only 400 miles on my new twin clutch and I am waiting to break it in as I work from home and I put less than 20 miles a week on my car. Its getting cold here and I have no time as I am buying a house. However, I AM GOING TO THE TRACK VERY SOON. I am sure that I will hit low low 12 or high 11s with my twin clutch (I can launch it pretty well)
IE you can’t compare BR500 with this turbo as they are 2 different applications for 2 different approaches so your point here is invalid.
Alex please stop acting like a kid and following me all over making none sense comments and I am happy for your turbo and your tune choice as well.
I am sure that none of you have driven an EVO with 3071 so don’t make comments and base you opinion on some yap yap yap from other people.
Az3ar you sound like a STI owner trying to justify your purchase. No lag! You have a good pump gas turbo and I believe you made 327whp on Shiv's dyno on race gas. If i am not mistaken you will always be at least 50 whp behind a 3037r on race gas just like I will be about 50 whp behind a 35r. I made 420whp on Shiv's dyno,400whp on 100 oct and 337 on 91 so you have alot of catching up to do. BTW I was not comparing the BR 500 to the ATP kit. I was making a simple analogy about talking and coming up short on the talked about numbers.In otherwords i was comparing your predictions to Evo8powas. Also i have driven in your car with 4 people in the car and yes it felt strong. I do not doubt that your car is capable as is and of more. But some of your conjecture is a lil optimistic. Wish you the best.
Old Oct 31, 2004 | 09:14 PM
  #49
Az3ar's Avatar
great, lets bring this thread back to topic.
Thanks
Old Oct 31, 2004 | 10:03 PM
  #50
Kwman's Avatar
...you guys want some hugs?
Old Nov 1, 2004 | 12:04 AM
  #51
Yaroslav's Avatar
Bigger turbo-bigger Lag, i don`t need LAG!
I think some people agree with me
3071 is optimal turbo!
Old Nov 1, 2004 | 04:57 AM
  #52
Ted B's Avatar
Originally Posted by Quickshift
So from what i understand you cannot excede what is wriitten in the compressor map???
You've answered your own question in an earlier post:
The stock turbo blows hot air at 25psi.
Every turbo (including GT30, GT35, etc.) reaches a point based on pressure AND rpm AND air mass whereby increasing the pressure further doesn't generate more power. Furthermore, the greater the pressure one can hold to redline with a given turbo, the less volumetric efficiency (power potential) he has.
Old Nov 1, 2004 | 05:14 AM
  #53
Ted B's Avatar
FYI: Presently I am one of at least several individuals considering one of a few turbo kits (including the ATP kits). There are pros and cons to all of them. This being the case, I am prepared to and intend to discuss the nuts and bold thereof, including the upsides and the downsides, the good qualities and the drawbacks - looking at all thoroughly and discussing the same. My comments are purely about hardware and are never anything personal, so don't assume otherwise.
Now go do what you need to do to put up the best numbers you can.
Old Nov 1, 2004 | 05:19 AM
  #54
Az3ar's Avatar
no hard feelings buddy. If i see I would shake your hand.
Old Nov 1, 2004 | 05:20 AM
  #55
Ted B's Avatar
Agreed.
Old Nov 1, 2004 | 09:38 AM
  #56
evo8r's Avatar
go ATP...my 3037s can open up a major can of whoop azz...
Old Nov 1, 2004 | 09:59 AM
  #57
Ted B's Avatar
Please list your mods and what type of dyno so that we can put your setup into perspective. A dyno sheet image would be helpful as well.
Old Nov 1, 2004 | 10:33 AM
  #58
Az3ar's Avatar
I think he has IC, pipes cams and cam gears. I believe he posted his dyno results with the dyno sheet some where on the forum. oh and he has AFC too.
Old Nov 1, 2004 | 12:07 PM
  #59
Ted B's Avatar
Found it. I'd like to know about the spool characteristics of this kit as well as if his cams are set straight up (no cam gears seem apparent).
Old Nov 1, 2004 | 01:05 PM
  #60
evo8r's Avatar
My cam gears are straight up..put down 360.21 wtq at 4700 rpms...i have full spool by 4200rpms....just wait and see....i will have AEM EMS with 800cc injectors...and i gaurantee 480-500whp...
