View Poll Results: which option?
A
0%
B
0%
C
100.00%
Voters: 7. You may not vote on this poll
What mods to get..
Old Nov 7, 2004 | 12:08 AM
Robbyh's Avatar
What mods to get..
Well now that my car has about 1700 miles on it, mods are being ordered
The items i already ordered are:
Hks drop in filter
Blitz T. Timer
Greddy Profec B.C.
Now here is where i could use some advice. I have a few options on what else to get right now.
option A:
cams 264/272
option B:
Apexi Afc
Greddy Type-s b.o.v.
Walbro f.p
option C:
Greddy bov
Apexi n-1 exhaust
Currently i'm leaning towards 'B'. My buddy thinks 'C' which is also a good choice at this eairly stage in the modding. But I just can descide.. Any help is appericated. All 3 option + the stuff i already ordered cost about the same so $ isnt a factor in seperating them.
Old Nov 7, 2004 | 01:03 AM
patsevo8's Avatar
First off, if you are going to run more boost, you're going to have to run more fuel. The Walbro 255LPH works wonders. Secondly, if you're having more air pushed into your engine, don't you think that you need more to be pushed out? Get the exhaust next. Thirdly, with all that in mind, you're going to want to 'tune' the air/fuel when you boost up your boost and pump more fuel. With all that boost you're going to be running you're going to need a good BOV to hold that boost, and it looks as if you have already picked one.
I have had good results with the SAFCII. Unless you're wanting ridiculous amounts of power, go stand alone.
Better yet, you can hook up with VISHNU and get one of there XEDE ecu's.
It's all up to you.
My opionion only here.
Old Nov 7, 2004 | 01:05 AM
SilverEvo8owner's Avatar
Cams!
then keep them on the side, keep putting more miles on it until you can get fuel management
with those on a stock exhaust it would be a sleeper!... for a while
Get the cams, keep them, then get fuel management with a cheap mbc until you can get an electronic
Dont try to put the cams in without management
Old Nov 7, 2004 | 01:31 AM
marksae's Avatar
Follow a proven staged upgrade path. I'd get a turbo back exhaust and a WORKS P2 ECU flash.
You don't need to upgrade our fuel systems unless you're cranking up the boost by a lot. As proven by the WORKS P2 flash, holding boost to redline does not require a fuel pump upgrade. A lot of people seem to report driveability issues after installing a high flow fuel pump so this requires retuning.
Old Nov 7, 2004 | 01:52 AM
XLR8R's Avatar
Rear sway. Best bang for the buck mod.
Had my 24mm WORKS rear sway installed last week. All I can say is HOLY CRAP, why the hell didn't the evo come this way from the factory.
Old Nov 7, 2004 | 02:34 AM
marksae's Avatar
I can vouch for the WORKS rear sway bar also. On the middle setting, the bar got rid of most of the understeer. I'm tempted to try the stiffest setting now to see if I can kick the tail out.
Old Nov 7, 2004 | 10:09 AM
Robbyh's Avatar
Thats kind of why i was thinking about getting the afc now, so i can tune it a bit. I plan on running 21 psi with the controller, no more for awhile. Also thought about the flash, but i think it would be better to get a good base 1st then do the flash.
Old Nov 7, 2004 | 03:43 PM
jonduke's Avatar
the flash would be your base,unless your referring to base level mods wich yes you would maybe want to flash when your parts are all on,but i think full 3"should be first on your list
and a fuel pump is more to prevent from starving your motor at high boost levels(the works flash is great but it reatains factory boost setting{19psi} just holds it until redline)thats why there is no need for upgraded pump w/ that
Old Nov 8, 2004 | 11:34 AM
Robbyh's Avatar
Ok i'm going with 'C'
Thanks guys.. Possably going to also get the fuel pump too, just to be safe..
PR_DSM
13
Feb 19, 2010 08:02 PM
jdmdc2r01
21
Feb 29, 2008 08:44 PM
702RSevo
Jan 11, 2006 08:54 PM
Halleys
Lancer Aftermarket Forced Induction Tech
26
Aug 5, 2005 03:29 AM
Hong Kong Evo
Jan 16, 2005 07:47 AM
