Need Some Opinions!!!
Originally Posted by Mr_Green
mitsubishi actually warranties their clutch to 12000 miles
OK guys. I just got my car back with my ACT HD clutch and Fidanza Flywheel. MY dealer put the set in for FREE. Why? becasue the trans was out for the TSB on the 5th gear issue. I went with the after market set up as the stock one is junk. If you burned your clutch you ruined your flywhell. There is a thin band just beyound the center hub that gets hot. You will see blue crescent burns on it from the engine side. The stock pressure plate capacity is close to the engine torque (actually measured by ACT). If you slip the clutch under boost it can easily over heat the flywheel and then start to burn the disk.
The stock f/w is 319 I got my Fidanza for 350. The ACT HD is rated about 400 lbs clamping force, almost 40% over stock. Hope this real life info helps.
evo racing
Sep 12, 2005 03:19 PM
thebluesky
23
Oct 3, 2004 08:45 PM
