Boost Too High On Avcr
Old Nov 19, 2004 | 02:46 PM
BADEVO's Avatar
Installed my AVCR today and I cant get the boost dialed DOWN. It Peaks at 2.11mmHG. Using the conversion table thats like 29 lbs of boost. Can anyone help.
Old Nov 19, 2004 | 02:50 PM
EVOla_VIRUS's Avatar
Check all lines.....make sure they go to where they are supposed to go(ie turbo nipple and solenoid)......dial in less gain if you can.....
btw, when I test and tune, I invest in 100 oct gas just in case.....29lbs is way toooo much...good luck!
Old Nov 19, 2004 | 02:55 PM
BADEVO's Avatar
OK I pulled the lines from the factory boost solenoid. I ran a line from the waste gate acuator to the AVCR Solenoid. Capped the Turbo and ran the opposite side of the solenoid to the nipple under the intake.
I ran the pressure sensor to the same line as where my boost gauge is tapped.
Old Nov 19, 2004 | 07:17 PM
BADEVO's Avatar
ANYONE??? This thing keeps boosting to 30 PSI......
Old Nov 19, 2004 | 09:37 PM
BADEVO's Avatar
Bump
Old Nov 19, 2004 | 09:53 PM
LancerOZ's Avatar
Are you sure your gauge is reading correctly? If you're spiking at 29 or 30psi of boost, you should be causing damage, like blowing your motor, depending on your mods and octane.
Your gauge could be off. at 30PSI I think you'd be having damage, and you haven't mentioned any. That's the only thing I can think of. Hope you figure it out.
- Jason
Old Nov 19, 2004 | 09:58 PM
BADEVO's Avatar
Both the AVCR and the Boost Gauge read 30.
Old Nov 19, 2004 | 10:15 PM
chinto's Avatar
what are ur settings for duty cycle?
also look for posts that i have done / posted in about the avcr should answer most if not all ur q' on where to tap and what ever else ifyou still have an issue respond to this and ill look them up being lazy playn some ps2
Old Nov 19, 2004 | 10:34 PM
chinto's Avatar
k found links friend took over playn ps2 for a whyll happy reading
https://www.evolutionm.net/forums/sh...ad.php?t=97169
https://www.evolutionm.net/forums/sh...6&postcount=12
https://www.evolutionm.net/forums/sh...ad.php?t=98250
Old Nov 19, 2004 | 10:54 PM
BADEVO's Avatar
AL gave me that info and you verified it. I had it routed wrong. Instead of going to the BLACK NIPPLE I was routed to the Nipple under the intake. I WAS HITTING 30PSI! I adjusted my AVCR, now I hold 20 STEADY! Thanks to all who volunteered thier time.
Old Nov 19, 2004 | 10:56 PM
Z2EVO's Avatar
Is the vacuum line going to your wastegate free of obstruction? No kinks and not being pinched in between other parts?
Old Nov 19, 2004 | 10:57 PM
Z2EVO's Avatar
outstanding!
Blitz_b9
Apr 10, 2012 09:26 AM
Blitz_b9
Apr 8, 2012 05:14 AM
jamie_v1
Oct 11, 2008 03:03 PM
AZ EVO IX MR
Jul 19, 2006 10:25 AM
1mbrews8
Jan 6, 2005 07:48 PM
