Hallman evo RX MBC install
Old Dec 2, 2004 | 07:56 PM
Evoisdream's Avatar
sorry if thier is a thread on this i have searched and cant really find anything other then a install for a turbo xs one dont know if its the same. Dont want to be sorry later on well i just got it today and i would like to install it this weekend if anyone has directions or a link that would b awsome thanks in advance. it also has the incockpit controller
evoisdream
Old Dec 2, 2004 | 10:37 PM
Evoisdream's Avatar
NO ONE? how sad where are all teh install masters!
Old Dec 2, 2004 | 11:18 PM
Jakeg97's Avatar
http://www.hallmanboostcontroller.co...tions%20ld.pdf
Old Dec 3, 2004 | 01:13 AM
Evoisdream's Avatar
Nothing comes up when i click that? is that my end or what
Old Dec 3, 2004 | 02:22 AM
EFIxMR's Avatar
the weak spring is way too soft, don't bother with it. use the stiff spring.
Old Dec 3, 2004 | 02:47 AM
rExTuHfEr's Avatar
but what if you didnt....
Old Dec 3, 2004 | 02:54 AM
EFIxMR's Avatar
with the soft spring and the boost control turned all the way down it only boost .7 bar, on the instructions it syas the soft spring will only raise it 5 psi. that is very far from a little under 1.5 bar, which is what you're shooting for. is it possible to use the soft spring?
Old Dec 3, 2004 | 03:05 AM
Deepseadiver's Avatar
soft spring works for me at 21 PSI.
Old Dec 3, 2004 | 10:02 AM
Evoisdream's Avatar
dif springs eh i guess i should look at the controller a bit more any one have install instructyions where boost lines go etc thanks
Old Dec 3, 2004 | 10:30 AM
EFIxMR's Avatar
if i remember correctly, the port inline with the controller goes to the boost source on the charge pipe, and the port going to the side goes to the wastegate.
Old Dec 3, 2004 | 11:15 AM
Evoisdream's Avatar
ok i got this to open at work thanks for the help i think ill try to set it up this weekend
ill take some pics and let u know how it ends up!
Old Dec 3, 2004 | 11:29 AM
EFIxMR's Avatar
this might take a little longer, but i found it easier to do once i removed the battery, intake box, and intake tube.
Old Dec 4, 2004 | 02:15 AM
EFIxMR's Avatar
don't use the soft spring, i tried it today and with it turned all the way it only gave me 1.1 or so bar.
Old Dec 4, 2004 | 11:22 AM
Evoisdream's Avatar
ok i need a little help i installed it and everything is working and i put the hard spring in and im still only getting 1 BAR can anyone help?
Evoisdream
16
Feb 26, 2005 12:43 AM
Evoisdream
Jan 10, 2005 12:25 PM
Evoisdream
45
Jan 4, 2005 12:22 PM
Evoisdream
Midwest Region
Dec 8, 2004 03:39 PM
Evoisdream
19
Nov 18, 2004 08:57 AM
