Quick parts updates....
Old Jan 19, 2005 | 09:11 PM
  #196
scorke's Avatar
Is the pressure in kpa/bar/something I don't know?
Scorke
Old Jan 20, 2005 | 01:21 PM
  #197
Fenris Ulf's Avatar
Scorke
The pressure is in the unitless measure of PRESSURE RATIO as stated on the maps
PR = (boost pressure + atmospheric pressure) / atmospheric pressure
Old Jan 20, 2005 | 02:48 PM
  #198
propellerhead's Avatar
Damn, the 20G just spanks the crap out of the 16G in terms of the size of it's efficiency range.
In general, what VE are peeps using to calculate CFM? Is a figure of 95% reasonable to use for a car with with a ported head and the usual breathing mods?
Old Jan 21, 2005 | 10:02 AM
  #199
David Buschur's Avatar
The stock injectors will work for atleast 90% of the guys that buy this turbo.
David Buschur
www.buschurracing.com
Old Jan 21, 2005 | 02:26 PM
  #200
NYREDEVO's Avatar
David Buschur
Thanx Dave, So assuming we did stage 1-3 plus the fuel pump what kind of track times to you think we could run (I apologize if this has been asked before and i know its only an estimate but just ball park) on pump gas...around 400 HP and lke 11.5 ish? Is that reasonable?
Old Jan 22, 2005 | 01:55 AM
  #201
MiSTER2's Avatar
Is the Buschur 20g suitable for someone who is not looking to push the turbo more then 18-20psi? I can see some advantages e.g 18psi on 20g making a little more then 18psi on 16g but is it worth it? Also bigger turbos provide cooler air but has this got to do with the size of the wheels or the housings?
Old Jan 22, 2005 | 04:21 AM
  #202
EVO8LTW's Avatar
And on that note, will the 20G allow higher levels of boost on pump without detonation?
Old Jan 22, 2005 | 04:37 AM
  #203
EvoTech's Avatar
David Buschur
I hate to disagree with someone who knows a lot more than I, but I do. I think that more than 10% of us have cams. With cams and this turbo, I believe that you will need to upgrade injectors. With just the cams my injectors were almost maxed about at 95% duty cycle.
Old Jan 22, 2005 | 07:08 AM
  #204
Corey's Avatar
I remember Al saying I needed to probably upgrade to 660's or 680's after I got my cams and custom tune a while back. He said my injectors were almost maxed out. I have now problem with upgrading if I need to though.
Old Jan 22, 2005 | 07:34 AM
  #205
Zeus's Avatar
That has a lot to do with your tune...
Old Jan 22, 2005 | 10:33 AM
  #206
marksae's Avatar
And octane of pump gas available.
Old Jan 22, 2005 | 02:45 PM
  #207
Fenris Ulf's Avatar
Yes.
Yes.
They provide a denser air charge at a given flowrate because the larger wheel does not have to spin as fast to flow the same mass of air and thus does not heat up the air as much.
Old Jan 22, 2005 | 02:46 PM
  #208
Fenris Ulf's Avatar
The 20G will allow you to make more power on pump gas than possible with the stock turbo.
Old Jan 24, 2005 | 09:48 AM
  #209
nyredevo,
400 whp with a fast spooling turbo will easily run 11.5's. We ran 11.65 at 117 mph with 390 whp.
David Buschur
Old Jan 24, 2005 | 10:30 AM
  #210
Yes, the 20G is very suitable for someone not wanting to run over 18-20 psi. It will make more power at that boost level than the stock turbo does, more air=more power.
The turbo will not allow more boost on pump gas than the stock turbo will.
Yes, a TD05H turbine mated to a reverse scroll 20G compressor is what it comes down to.
David Buschur
