Whoops too much boost? 23psi!
Old Dec 14, 2004 | 11:55 PM
fuzzychi's Avatar
I was driving today checking out to make sure I had the MBC set correctly for 20psi till redline but I guess it was really cold and I got up to 23psi!!.... Then the car kind of shook well felt like a fuel cut and the "Service Engine Soon" light came on..... did I do any damage and what happened?
Old Dec 15, 2004 | 05:27 AM
GTVEVO's Avatar
Weather changes and a MBC just don't go well together. This is really about their only downfall though. You probably did hit fuel cut or overboost and the ECU threw a code. Just unhook the battery for a few min and let the ecu reset and turn down your mbc and take it back out. You should be fine.
Old Dec 15, 2004 | 11:05 AM
ebbeast2005's Avatar
^^ Been there done that. Its cool just a overboost code it will go off or you can just reset the bat. like gtvevo said above.
Old Dec 15, 2004 | 11:16 AM
TampaTurbo's Avatar
wierd...I hit 25psi and never threw an overboost code. Owell.
Old Dec 15, 2004 | 11:19 AM
Rez90's Avatar
the car is fine...i used to boost 22-23 psi all the time
Old Dec 15, 2004 | 11:21 AM
a1andres's Avatar
^^^the car probably is fine
BUT, you shouldn't just let the MBC stay at it's current position. Like someone said, this is an MBC's biggest weak point. It does not adjust for outside temp. If you are not letting your ECU control your boost, then you need to be very attentive to what boost levels you are hitting...
Old Dec 15, 2004 | 11:27 AM
scott88vr6's Avatar
Good points made by all. Good luck.
Old Dec 15, 2004 | 12:00 PM
Blitzbaster02's Avatar
your car is fine
Old Dec 15, 2004 | 01:22 PM
patsevo8's Avatar
Dude, I had my stuff installed at a shop in Utah. Well, they set my MBC for 30psi. I ran it like that for a few months UNKNOWN until I took it to Modern. Luckily I didn't hurt anything. Well to the best of my knowledge.
Old Feb 24, 2005 | 09:54 AM
yesevo's Avatar
how to adjust boost right after it installed ? do u have to run the car to redline to check the max boost ???
Old Mar 11, 2005 | 01:18 PM
30 psi... Your car wouldnt do it theres no way. I can see like 23 but at some point your spark plugs would be melted piece of metal.
EriCS
Feb 17, 2012 08:05 AM
Mauricio Evo IV
35
Dec 8, 2010 05:54 PM
5LEEPERISAH23I
Nov 2, 2010 08:39 PM
FJF
Jul 22, 2008 03:08 PM
purekoryo
Jul 11, 2008 01:16 PM
