Big Problems???
Old Dec 26, 2004 | 07:35 PM
BSREVOLUTION's Avatar
Old Dec 26, 2004 | 08:23 PM
SuperchargedGTZ's Avatar
when i did a compression test a while back, because i freaked out when i blew my oil stick out, i had 165 across the board
i guess if they are just all consistent than it is all good
Old Dec 26, 2004 | 08:31 PM
Jakeg97's Avatar
Originally Posted by BSREVOLUTION
im thinking my gf kicked thw switch last night while we were driving. .
how did that happen
Old Dec 26, 2004 | 08:35 PM
nothere's Avatar
is this where the thread goes NWS
Old Dec 26, 2004 | 08:47 PM
Quickshift's Avatar
Your compression will vary depending if the engine was just run and that there is a good amount of oil still on the rings, which in turn will give you a higher reading. But if the car had been sitting a while (ei. cold engine) then was just tested then a lower reading would show up. But the fact that it is consistent across the engine it is good
Old Dec 26, 2004 | 08:51 PM
DynoFlash's Avatar
try the compression hot - generally if they are all even you are cool
Old Dec 27, 2004 | 09:33 AM
cool, yeah the car was sitting for about 4hours before the test. and the switch was kicked because i haven't found a place to mount it yet. im going to see if it fits in the ic spray button position.
moyassine
Feb 21, 2016 10:54 AM
Indianbrandon
Dec 28, 2012 01:20 AM
mikeymisfit
Lancer Troubleshooting
25
Mar 7, 2007 06:29 PM
FeRRarI eAtR714
25
Dec 20, 2005 10:34 PM
TrskitEvo8
16
Jun 23, 2004 06:14 AM
