Check Out My Custom Header and Turbo Install!
I did not want to seem like this was a rude plug so here is his contact info ( it is also on the sight ) email: tym@switzerperformanceinnovation.com and work number is (440)323-0060. Thanks for all of the compliments. Tym is a great guy and my friend.
Originally Posted by evoviiiyou
More piping for long tube header design. The bennifits of long tubes has been used in racing for many many moons, ie maximum flow and equal exhaust distribution. But most important is the location the header puts the turbo in. Right below the vent on hood for maximum heat extraction, to make the vent actually functional!
Sure stock vs. stock, but thats another thread. Thats what strokers, nitrous, and smaller turbos are for. Being an Evolved member you have to know the advantages of this design with the proper set up.
the issue isn't the equal length manifold, since there are ways to get equal length WITHOUT completely elongating the manifold (e.g. RNR's setup).
What im curious about is what benefits are to be had by simply increasing the length of the manifold tubing by itself. ??
Alex, that's not a long manifold. It's longer than stock, but you'll never notice the difference. In fact it will only work better.
A long manifold are the gm guys putting the turbo back by the rear end.
The advantages of the length of the tubes has to do with breathing and drivability. With my setup it allows optimum spool where my combo requires it. Remember I am not saying bolt this header to a stock turbo set up with no other work done. This is one part of a recipe of mods to maximize what we want as far as maximum power where I want it.
Thats one of the bennefits with this set up. The heat can escape through the factory vent. At speed it should do wonders for temp. I will have pics with down pipe later. Stay tunned.
Man that is real beautiful setup, I just cant stop saying wow to myself. Wish I had the bones to throw down and put that beautiful setup on my car cause I would do it in a heart beat
staton
staton
How does that fit with the stock radiator? Most turbo kits already put the turbo very close to the rad. I don't see how this will fit, unless the angle of the picture doesn't put things in the right persepective.
