Check Out My Custom Header and Turbo Install!
Old Jan 28, 2005 | 02:44 PM
  #61
evoviiiyou's Avatar
Good point. I guess I just wanted something different. Unless we try new thingsI guess we cannot make progress. I will post the dyno #'s when I get them. It will be interesting.
Old Jan 28, 2005 | 02:47 PM
  #62
mike 99gsx's Avatar
I wouldn't be too worried about Tym's design and implementation ideas as being "experimental". This is the same guy that made 821whp on a DSM WITHOUT nitrous.
Old Jan 28, 2005 | 02:49 PM
  #63
evoviiiyou's Avatar
Yeah, I fully trust him and his workmanship. I just wanted to share the info. Wow I did not know that he made that much power. That is incredible.
Old Jan 28, 2005 | 03:08 PM
  #64
Ted B's Avatar
I wouldn't be especially concerned about it. The nominally longer runners shouldn't really hamper peak power anyway. If anything, longer runners would soften the tip-in boost response, which obviously won't show up on a dyno sheet anyway.
Old Jan 28, 2005 | 03:14 PM
  #65
evoviiiyou's Avatar
I'm learning so much from this site. Hopefully all the advice can help others as much as it is educating me. Thankyou all.
Old Jan 28, 2005 | 03:23 PM
  #66
fimotorsports's Avatar
very nice setup! As far as exhaust runner length on Subaru and the 4g63, I believe the stroke may play a factor in the spool up time, more so than the exhaust runner length... longer stroke on the 4g63, intake manifold design, cams, head design etc all play a roll.
92 x 75 mm wrx
85.0mm x 88.0mm evo
Old Jan 28, 2005 | 03:28 PM
  #67
Ted B's Avatar
No, the stroke length makes no difference where runner length is concerned. The overall displacement and int/exh head flow characteristics however affect optimum port/runner size.
Old Jan 28, 2005 | 03:30 PM
  #68
evo542's Avatar
I think the concept is good, since heat rises - the exhaust gas velocity shouldn't drop too much
Old Jan 28, 2005 | 03:35 PM
  #69
soule77's Avatar
Nice setup, I would be interested to see some dyno numbers once you get her installed and tuned.
Old Jan 28, 2005 | 03:40 PM
  #70
Ted B's Avatar
That's true and good to know...when you're roasting marshmallows over a hood vent.
In actuality, whatever difference there may be in such an instance would probably not be something quantifiable on a dyno.
Old Jan 28, 2005 | 04:17 PM
  #71
evoviiiyou's Avatar
I luv roasted marshmellows and smores. Especially @ the raze track.
Old Jan 28, 2005 | 06:15 PM
  #72
evoviiiyou's Avatar
Anymore input on this set up so far:
Bennifits:heat evactuation (at speed), unnoticable exhaust velocity loss(turbo spool), looks good, top end power and marshmellow roasting
Negatives: inefficient tube material(slow down velocity of exhuast gas), not proven to produce added performance
Old Jan 28, 2005 | 06:23 PM
  #73
plokivos's Avatar
looks like you'll get a straight intake with the turbo mounted high.
looks great! big freaking wastegate. What sort is it?
vid would be great!
Old Jan 28, 2005 | 06:29 PM
  #74
mike 99gsx's Avatar
Tial 44mm
Old Jan 28, 2005 | 06:53 PM
  #75
Geo@EvoStore's Avatar
I can't wait to see some of the cars Tyms shop puts out. He definately does some sick work.
We have a customer with a similar designed header. That collector in that picture looks like it is more efficient just by first impression than the one this local has.
