Check Out My Custom Header and Turbo Install!
Les,
you are a pimp!
question: What is that aluminum collector(?) above the top of the intake? is that just to divert the air?
Soo many questions to ask... can't wait to see the real deal.
you are a pimp!
Originally Posted by trinydex
...this is where i contest... i believe that the twin scroll design as mitsu explained it is to reduce reversion... the twin scroll becomes a necessity because you can't stack pulses in the runners.
...and i do believe there is SOME benefit to long tube design and i've said this before. i think that the longer your tube the more pulses you can "stack" in the tube which means when they get to the collector... less stuff can travel back UP the primaries because something is on it's way down to push it in the right direction.
There will be some air diversion, but it is a custom battery mt. I belive you mean that aluminum square piece below and right of the K&N. Anyway when we cruise you can see it and in person.
Originally Posted by rsboy
Les,
you are a pimp!
you are a pimp!
I guess I don't really know alot about the pulses and preasures, but this design is claimed to be more efficient for my needs as true street car with 600 awhps. I trust in Tyms ability and knowledge to produce at what ever cost.
Originally Posted by Ted B
Not really. A twin scroll has a lesser tendency for reversion by virtue of its design, but in reality, there isn't enough overlap in the factory cams to make reversion a significant issue for Mitsu. Why not whip out your calculator and tell us what rpm you'd have to turn to 'stack' pulses in one runner anyway? I think you'll find that number to be well off the end of your tach. The primary purpose of the twin scroll design is simply to minimize lag and improve low speed response.
Again, just use a calculator and look at the specifics. What applies to exhaust design for normally aspirated cars cannot be directly applied to any app that pressurizes the intake.
For info on that rad just call 440-323-0060 and ask for Tym or Matt, they can help you. Thanks for the kind word everybody.
Originally Posted by kcevo
Any info available on that radiator? Koyo part number perhaps?
CatalystGod
Evo X How Tos / Installations
20
Dec 12, 2016 01:36 AM
Revhigh
Evo 'For Sale' Wheels / Tires
54
Oct 4, 2005 07:37 AM
