Check Out My Custom Header and Turbo Install!
That's a pretty cool set up, really nicely put together, I hope it works as good as it looks!
I have always felt that Bushur's 4 coil ignition set up was the slickest LOOKING part in his line-up.... thanks for introducing Mr. Switzer to those of us who didn't know him.
Originally Posted by alex_alex
hmmm. I always thought one of the advantages the 4g63 had over the Subaru engine was its ability to place the turbo so close to the engine itself so that the exhuast gas would have to travel a much shorter distance to spool the turbo.
You are correct.
Tuning via runner length is largely inapplicable in a turbo setup simply because unlike a N/A app, the intake is (sigificantly) pressurized. What the extra length does is cause the pulse to lose more heat and velocity en route to the turbo, and reduces pulse energy to spin the 'wheel'. How significant this turns out to be in this case is anyone's guess, but the setup looks very, very pretty.
Originally Posted by evoviiiyou
The advantages of the length of the tubes has to do with breathing and drivability. With my setup it allows optimum spool where my combo requires it. Remember I am not saying bolt this header to a stock turbo set up with no other work done. This is one part of a recipe of mods to maximize what we want as far as maximum power where I want it.
It looks like a great setup to me. In the end you are trying something new which we always want. Dont worry things might turn pretty well and many will follow your route. These are not very long runers and I wont be very worried about this part. These will defently give you top end power (not sure about spool though). Looks like the 3071 that I am using which has great spool and lovely top end so you should be ok. I would like to see a pic of the DP if you can. Good luck
Mhyar
Mhyar
No problemo. I guess I had a pwer band in mind with a pwer figure and with Tym's experience he came up with this to optimize his ability to dial in the power curve for my needs.
you know if you go back a year ago everyone would swear up and down on HKS turbo kit and today no one is putting them before any of the domestic kits out here. What you are doing now is a great benefit for the EVO community as you are spending money and time trying things we have not tried. I know that the DP must go from above because that’s how your turbo sits. Which engine management are using for running?
Good work dude, it looks frickin awesome!
