Max Boost around 12-15 ???
Old Feb 11, 2005 | 06:07 PM
GIsnickers's Avatar
Ok,
I did see a few posts on this but no one seemed to reply saying anything worked etc...
Anyways, Just got the car 2 weeks ago. Love it. Just recently me and my buddy installed an intake. (Yes, I also reset the ECU.)
After the install, I noticed on my boost gauge that my max boost being put out is around 12-15 in low gears and around 10-12 in 4th and 5th gear. Now I didn't pay attention to the gauge before this, but the car seems to not have as much pull as it did before the installation of the intake..
Anyone have any ideas as to what to try in order to fix this?
Old Feb 11, 2005 | 06:14 PM
GreedMOTO's Avatar
Check ALL your vacume lines and connections. I loose/ripped line could cause an issue.
Check the fitment of your upper I/C pipe too. You could be loosing boost at a bad seal.
Old Feb 11, 2005 | 06:35 PM
BlewBuYou66's Avatar
what intake are you running? and did you fix the problem? or did the problem just work its self out?
thanks
Old Feb 11, 2005 | 06:36 PM
GIsnickers's Avatar
AEM Shorty intake; gonna recheck all the lines tommarow, but I am pretty sure they were all nice and tight.
Old Feb 11, 2005 | 06:51 PM
dr.mr's Avatar
I had a similar problem, the vacuum line that attaches to the boost guage was loose.
Old Feb 11, 2005 | 07:50 PM
BadazzCR's Avatar
check and make sure that the lines to the wastegate solonoid are correct and have the right restrictor pills in them.
Old Feb 11, 2005 | 08:00 PM
berkel's Avatar
Whatup,
My IC hose popped off at the TB this morning. I had read other posts about this, but didn't think it would happen to me.. I even have a tbolt clamp and Samco hose, but I just didn't tighten the clamp enough... I put it on at a better angle and got it much tighter.
Car hasn't been running great though, only reading about 18 psi of boost. My SAFCII also picked up a lot of knock, Perhaps the hose popping off made another hose or vacuum line loose somewhere? My vacuum at idle still reads between 18 and 20 inHG and Karmann reads ~25 at idle like it has before, but the car feels sluggish and doesn't sound right.
Oh well, just double check all the IC hose connections and vacuum lines. I'm going to do the same, good luck!
FB
Old Feb 12, 2005 | 07:13 AM
GIsnickers's Avatar
I checked all my lines this morning...
I did notice that my I/C clamps were infact stripped and not very tight. Replaced them with new clamps and sealed them nice and tight.
I did see the boost going up to around 19 when I stepped on it, but slowly dimming off..
I'm honestly just wondering if I have gotten used to the power of the car and this is all in my head lol..
I can't see anywhere else it could be leaking from....Could I possibly have a leaky BOV? How would I be able to tell?
Old Feb 12, 2005 | 08:19 AM
GIsnickers's Avatar
Resealed the clamp where MAF connects to intake tube, looked a bit loose. Not sure if that was it but the problem seems to be solved. Power seems to be back and consistantly hit 19psi now!!
Thanks everyone!
kliped
Nov 23, 2013 03:36 PM
evodrivesme
24
Aug 14, 2010 05:51 AM
spoolking
Oct 15, 2006 04:11 AM
import111
West Region
Jun 22, 2005 03:34 PM
GTRMotorsports
May 27, 2005 07:26 PM
