Transfer case gone, replace clutch?
Originally Posted by lexxtek
yeah u better make sure they put diaqueen lsd oil part# 377610 it's about 60 bucks for a 5 liter can, i called around here chicago area who carries that oil and believe it or not i only
found one dealer that have it in stock, now i can only imagine what are those dumb a$$es
are using when they service an evo.....
http://www.mitsubishiparts.net/cart/?pn=3775610
Originally Posted by superz
You can remove the t-case without touching the tranny by splitting the tail of the t-case off, this gives you enough room to remove it without ever touching the engine mounts or the subframe. The stock flywheel can be resurfaced easily by any machine shop, its absolutely necessary when replacing a clutch otherwise clutch chatter and improper break-in may occur.
Anything else to be aware of when pulling the TC?
Originally Posted by GOKOU
I think my tc is going as well? Anyway to check for this?
John when are you guys offering to remove the TC and rebuilt as well? Price?
Jon@TRE
Originally Posted by revolagoy
I have only had the dealer service the drivetrain. Hopefully the ******** put the correct fluid in! I would assume the correct fluids are what the manufacturer recommends. Is this what you mean?
Originally Posted by EVIL_EVO_VIII
Yeah. Sometimes techs at the dealers are stupid and put the wromg fluids. Have them analyze them. I almost had a mitsu tech put the wrong fluids in last weekend!!
I've tried on several occasions to get in touch with anyone who gives a damn about making sure that the Mitsu techs are putting in the correct oil.
Think about it, all it would take is for someone to get off their **** and send a memo to every dealership that services these cars. It could save them a bunch money...
Jon@TRE
pawpaw
10
Oct 9, 2016 03:17 AM
