HKS SSQ BOV Adjustment???
Old Feb 20, 2005 | 12:59 PM
TrinaBabe's Avatar
I installed the BOV and it flutters horribly. At anything from 2psig to 10 psi it flutters about 4-5 times. At 17-19 psi it flutters once then relieves all pressure. I read about an adjustment screw on the back of it which mine doesnt have. Anyone know what the deal is?
Old Feb 20, 2005 | 01:03 PM
si_eater's Avatar
Question
you dont have a screw on the back? you should have one, thats odd check again and if you dont have one maybe thats what your problem is, oh and it doesnt look like a screw it looks like a bolt,
Old Feb 20, 2005 | 02:18 PM
TrinaBabe's Avatar
There is nothing on the back. I have had one before and know exactly where it would be. Its not there Its just a full aluminum cover with the 8-10 allen screws holding it on with one vacuum nipple. I just got this one very recently. Other than there not being the screw it is identical to all others i have seen or owned. Anyone?
Old Feb 20, 2005 | 02:43 PM
sleet's Avatar
They might have taken it off because you wern't suppostue touch that screw, it doesn't adjust the bov at all.
Old Feb 20, 2005 | 02:50 PM
si_eater's Avatar
Talking
no need to get fiesty ,maybe sleet is right maybe they removed it, its not used to adjust for our cars anyway, your not supposed to touch it (or thats what they told me, i asked the same question before)
Old Feb 20, 2005 | 03:03 PM
Evo_Tuner's Avatar
The screw/bolt was used to adjust it only if it's leaking boost. It'll only make it stiffer not softer and it will always flutter. I even changed the spring in mine to a softer one and it still flutters.
Old Feb 20, 2005 | 05:15 PM
03venom's Avatar
There is nothing wrong with the HKS unit. The ssqv flutters... period.
Old Feb 20, 2005 | 07:31 PM
GreedMOTO's Avatar
Correct. Maybe HKS removed the screw b/c we are not supposed to touch it...
Here is the letter I received from them a long time ago concerning the HKS BOV and the flutter.
https://www.evolutionm.net/forums/sh...ad.php?t=88637
Old Feb 21, 2005 | 08:17 PM
16g-95gsx's Avatar
How bad is this valve supposed to flutter though? Mine acts the same way, fluttering rediculous amounts at virtually any boost level. Under WOT, I have the same thing, it will blow off and then have a flutter to it by the end, its awful. My two friends both have the same valve on their supras and it simply just blows off, without any form of flutter under even extremely mild boost levels, 2-3psi or so. I just dont get it.
Old Feb 21, 2005 | 08:25 PM
midwestmonster's Avatar
I don't know of too many cars that run "good" with that bov that were using the stock maf. I had it on my car and it never worked right, recirculating or venting. You might want to think about a different valve.
Old Feb 22, 2005 | 12:21 PM
16g-95gsx's Avatar
I run a blow through airflow meter on my gsx, its not the stock karman vortex setup anymore.
Old Feb 22, 2005 | 01:37 PM
ProStreetOnline's Avatar
The bov flutters, it's a "feature". You aren't supposed to adjust the screw on the back anyway, I don't know why they put it there.
Old Oct 1, 2014 | 10:44 PM
EvoXJoel's Avatar
I installed a hks super sequential bov on my Evo X and it was only holding 13psi of boost has anyone had this problem or knows how to fix it please?
Old Oct 2, 2014 | 06:45 PM
Bhsj13's Avatar
i suggest a good fix is get an evo 9 oem bov if you are running 25psi or less.
Old Oct 10, 2014 | 10:09 AM
joeBPUsupra's Avatar
Only the old school HKS bov's are adjustable.
victim619
13
Mar 19, 2012 06:45 PM
Tachyon56
19
Sep 22, 2010 08:07 PM
HPEVOX
27
Apr 14, 2010 06:23 PM
dvd_mi
Mar 1, 2010 03:02 PM
AZ EVO IX MR
10
Sep 19, 2006 09:36 AM
