View Poll Results: Whats your pleasure, I mean pressure..
Voters: 58. You may not vote on this poll
Cylinder pressure, whats your number..
Interesting...
I did a compression test today.
131/131/130/130
I guess I am now a little concerned. At least they are close to each other.
I think a leak down is in order
Edit: Just corrected my pressures for altitude.
153/153/152/152
131/131/130/130
153/153/152/152
Did the test again for about the 10th time however I did two separate test because there is not any official instructions as to how many times to cycle the starter
So first test is with 4 turns of starter and second run is with 7 turns
1) 175-176-174-186 (four starter turns)
2) 189-190-190-196 (seven starter turns)
OK every on, which run is most accurate, #2 I hope is it because of only 7 psi diff.
Nonetheless, #2 is how I allways did the test and with same results from 1st time.
I need expert opinion here thaks
Former Vendor
the rule is you should be at top psi by 4 revolutions of the motor.. just watch the needle jump 4 times and thats your number.. thats the industry standard.. its a little odd, the one being higher than the rest. but nothing to worry about.. your fine and have good numbers..
03-04 evo's thats a good number..
Former Vendor
i have checked 3 diff evo's with diff. years, and i come up with 150-155 range.. last i heard, dont quote me but im pretty sure the shop manual says around 150 for our cars.. i wonder why so many cars are reading this high.. itzwolf how did you perform your test and what gauge are you using..
Not sure the actual gauge, it was my buddies kit that has leakdown also.
I have 272 cams and no advance/retard of my cam gears. Car was hot, let sit for about 30 minutes, the test was performed with throttle 100%. I forget how many turn overs to be exact this was a few months ago. I am at roughly 5-10ft above sea level too.
Also the car consumes no oil.
Former Vendor
how do figure that.. longer durations, higher lifts, promote the valve to be open longer.. thus not giving an accurate reading.. in cases of aggresive cams you would want to do a running comp. check. then you would have better readings than just cranking the motor over..
I'm still somewhat bothered about why it takes at least seven starter turns to get the peak pressure when everyone else does fine with 4 turns.
Another concern is the higher reading on #4, it's either 1, 2, and 3 are low or 4 is just unusually high.
Who knows, car runs fine - a little knock prone (probably 4) and was a little underpowered off the lot but does just fine now with mods.
Originally Posted by Ted B
FWIW, if you've made changes such as cams and/or cam timing, you can throw the factory compression test specs out the window.
Yes....I have 272/272 cams and mine read 175, 165, 165, 175....at 3000 ft elevation. My car is damn quick for the mods and the elevation I run at.
MRfabolous
48
Aug 17, 2017 07:15 PM
CtSilver03Evo
10
Oct 14, 2011 04:14 PM
overlord2kx
Nov 30, 2010 08:55 AM
