Keep my S-AFC and Flash, or just Flash???
Old Mar 20, 2005 | 06:47 PM
EVO8LTW's Avatar
Originally Posted by turbolarry
Show me a log of that flash.
When I tried to tune an AFC on top of a flash it was dead flat timing from 3000-5000 RPMS. Despite any fuel adjustments I made at these RPMS the timing would not budge. I went to the point of .98 volts (stupid rich) nothing, dead flat timing, 5 degrees. At 5000 RPMS the timing then started to advance, but starting so late, it would only peak at 17 degrees at 7000 RPMS. Bone stock the ECU will give you 20 degrees.
Well, the AFC isn't going to affect timing as much if you are starting with a flashed ECU since the corrections are going to be less. But the point of the flash is to get the timing where it needs to be and then the AFC should be used just to fine tune the fueling. If there isn't good timing with the flash, then the flash needs work. But even if timing doesn't move, there is power to had from a flashed ECU by leaning out the mixture to something more reasonable than the typical mail-in flash.
kf6ytc
Nov 8, 2006 08:55 AM
LostSoul Evo
Jul 26, 2005 05:46 PM
cyberninja
Mar 29, 2005 05:55 PM
Drive02Lancer
Lancer Engine Tech
19
Jan 7, 2005 04:54 AM
IgotaWhiteOne
Dec 25, 2003 10:11 PM
