Help here, new project
Old Mar 21, 2005 | 07:00 PM
Randy's Avatar
Ok people after a fatal accident to my WRX wagon 2004, Im buying a 2005 EVO and here's what I will use so far when I get my car.
AEM EMS with UEGO map sensor 3.5bar
Hallman MBC
HKS 272 cams
Injen intake and intercooler piping
Greddy Type RS BOV
Suggestions on what else I may need, exhaust? which? pricing? etc Not many things to buy please
Thanks
Randy
Goal: 350 whp on pump gas if possible
Old Mar 21, 2005 | 07:02 PM
KILTERMAN's Avatar
with a TB and fuel pump you should be right around your goals\\TB is around 750 - 1200 and fuel pump is 80-100 Good luck
Old Mar 21, 2005 | 07:06 PM
evo_whiplash's Avatar
+1
Old Mar 21, 2005 | 07:07 PM
Curt@MrLed's Avatar
Former Vendor
.if you have aem, u dont need a b/c.. might i recommend autronic.. if your going that route..i did..but i did it for a little more power, the result, i get 33 mpg. that was the real goal..
Old Mar 21, 2005 | 07:12 PM
scottsee's Avatar
man, you guys have some $$ to spend!! us poor DSM guys dont even consider AEM EMS!! ****!
Old Mar 21, 2005 | 08:21 PM
SilverCOEvo's Avatar
TBE for sure...depending on your budget, you can get pretty expensive (Ti exhausts), but if you just want performance, they can be had for reasonable numbers. Fuel pump is probably necessary with those mods (based on what I've seen, most upgrade to avoid problems, not after having them...but some can speak to having problems.) After that, it's just what you want out of it. Bigger injectors, I/C, bigger turbo...fun fun.
Old Mar 22, 2005 | 08:38 AM
Ev0 1's Avatar
And Head studs!
Old Mar 23, 2005 | 06:35 PM
Randy's Avatar
Ok I got a real question here.
264 CAMS or 272 CAMS? Let me know people, Im shooting for the 350 whp mark.
Thanks
Old Mar 23, 2005 | 06:38 PM
bolsen's Avatar
who's car is this? Ours or yours?
Old Mar 23, 2005 | 07:02 PM
SubiEvolved's Avatar
you dont need an aem to reach the 350whp marc. A flash works and is a helleva lot cheaper
Old Mar 23, 2005 | 07:03 PM
Randy's Avatar
Easy, I have no idea which would work better.
If you wont help then dont post
Old Mar 23, 2005 | 07:18 PM
vletnguyen's Avatar
if you go with aem ems.. then go 272 cams.. your idle will be like stock.
the boost controller is not needed since your ems can control it.
you will also need turbo-back exhaust and fuel pump. head studs if you plan on boosting high.
most, including myself have almost 350whp on 93 with everything you mention minus ems.
it could be done with a flash
Old Mar 23, 2005 | 07:23 PM
Randy's Avatar
So I can send my ECU to Turbotrix for example with a list of all my mods right?
If so I will call Mark tomorrow
Thanks man, I can save some of the AEM money for now and buy the complete turbo back
Old Mar 23, 2005 | 09:07 PM
timzcat's Avatar
How about driving lessons.
Old Mar 24, 2005 | 04:19 AM
Randy's Avatar
I think I can teach you how to drive
Come to Puerto Rico and we'll see who drives better
Thanks for the help people.
Randy321
Apr 23, 2016 06:38 AM
Randy Andrews
Outlander Sport
Feb 28, 2014 04:19 PM
David Buschur
63
Apr 10, 2011 11:48 AM
Randy
Aug 17, 2005 04:03 PM
