Clutch pedal floored!
Old May 27, 2010 | 06:41 PM
  #31
iroc's Avatar
Originally Posted by MitsoKid
this has happened to alot of members lately. It happened to me. Fluids are all full and no leaks.... The clutch slave cylinders go bad, assuming you don't have air in the lines. I'm also noticing this happens to alot of people using Exedy Twin HD's. I wonder if that has something to do with it? Its a PITA to replace because its located behind the drivers side shock mount. I pulled the whole assembly out from the firewall to replace mine
behind the shock tower is the clutch master, the slave is bolted to the trans... but i guess it has to do with age/ miles. I don't know but i figured if it is an inferior part there should be an aftermarket up grade??
Old May 27, 2010 | 09:18 PM
  #32
MitsoKid's Avatar
haha sorry, i meant master. My master went bad, not my slave. Not sure why, i pushed in the clutch one day and it stuck to the floor. Took my motor out to get built and there was some orange corrosion on the clutch line.. replaced the master and it fixed it
Old May 29, 2010 | 01:46 PM
  #33
camMCLEAN's Avatar
I'm dealing with this exact problem as we speak... if it is infact the slave that failed the dealer should warranty it because i have a 100k mile powertrain warranty, correct?
its the OEM clutch and failed under normal freeway driving conditions with ZERO indication that it was on its way out.
Old May 31, 2010 | 04:26 PM
  #34
DonHugo's Avatar
well, got a call from the mechanic and it appears that the throwout bearing went bad and that's what caused the clutch to go. but they had a TB in house and tried to replace it but he said that the fingers on the clutch were bent and would not allow the TB to go on and so he's going to have to get a new clutch. Upwards of $2k. FFFFUUUUUUUUU!!!
Old May 31, 2010 | 04:31 PM
  #35
yahh's Avatar
Its all up to the dealership. They SHOULD cover it, but who knows if they will. Do you have any mods?
Alohatrev808
Aug 30, 2014 07:03 PM
evilution09
Sep 6, 2010 11:19 PM
TIGERJC
Apr 1, 2010 06:41 PM
bustin
12
Aug 8, 2009 10:22 PM
LakerRaider
10
Jun 21, 2009 10:59 AM
