I think I have the lowest cammed evo ever!?!?
Old Apr 7, 2005 | 02:24 PM
  #31
UT_Evo's Avatar
No, only if it's at 0 when the car is off, and even then you can't fully trust it... my gauge is off by 2 pounds...
Old Apr 7, 2005 | 02:28 PM
  #32
SterlingEvo's Avatar
I guess what I mean is if it holds (whatever) boost level all the way out without dropping. Wouldn't a leak cause it to drop or fade? Or not necessarily? Seems like I shouldn't be so dumb as to ask this question, but what is a better way to check for a leak, if it seems to be holding just fine?
Old Apr 7, 2005 | 02:30 PM
  #33
UT_Evo's Avatar
A lot of things cause the boost to taper, it's set-up stock to taper... The best way to check for a leak is that vacuum seal test thing... a mitsu dealership can do it for you
Old Apr 7, 2005 | 02:39 PM
  #34
Cajun Power's Avatar
Even if his boost gauge was off by 5 lbs ot would be off by 5 lbs at 20 psi and not off by 0 at 15 psi. If he is showing 22 psi and holding to redline + or - one to two psi then he should be good. If he boosts up to 22 psi and leaks down to like 17 then I would worry about a big leak. But on a dyno someone should have heard a leak if it was that bad.
Just my thoughts.
Old Apr 7, 2005 | 03:01 PM
  #35
Just my thoughts.
That's what I meant. It was kind of hard to articulate online
Old Apr 7, 2005 | 03:12 PM
  #36
watchout's Avatar
I have 272/272 and my Compression reads 170-175 across the board. 150 does seem kinda low. Lower compression would tend to mean less power, or a loss of power. From what I have read you should be in that 165-180 range. just my .02
Shane
Old Apr 7, 2005 | 03:16 PM
  #37
Aby@MIL.SPEC's Avatar
Who did the cam install? Are you 100% cetain that everything went back together correctly? I dont know how much power you would loose by being 7 deg's off in either direction....
Old Apr 7, 2005 | 03:25 PM
  #38
SwiftEVO's Avatar
My car isnt laggy at all. It spools hard as hell.
I put the cams in myself. Everything went vey smooth. I even bled the lifters.
--Josh
EvoJay
Feb 19, 2009 12:06 PM
jhall651
May 26, 2007 12:37 PM
NWEvoViii
Northwest Region
May 12, 2007 12:36 PM
stikillller
Mar 22, 2006 05:22 PM
BigLEVO
Apr 5, 2005 09:46 AM
