Highest EGT
Old Apr 8, 2005 | 12:33 PM
Eugene's Avatar
Highest EGT
Hi. Could you please post you highest EGT, at what speed and gear it was and what gauge you are using?
Everybody please post, this would be very interesting to see!!!
Old Apr 8, 2005 | 02:05 PM
tasco's Avatar
Well, 5th gear on the freeway at about 3.2k Im at 600. The highest I ever went was about 700 driving to vegas. I have the greddy 52mm egt BTW.
Old Apr 8, 2005 | 02:07 PM
EVOL EDO's Avatar
highest was 14-1500? at around 90-110 on throttle in 5th gear, but as soon as i let off throttle it drops to like 12
Old Apr 8, 2005 | 02:27 PM
SilverCOEvo's Avatar
I've seen 1500+(F) while on the interstate...probably 1550ish, never over 1600, but I've seen in EGT posts of people hitting 1600+ if I recall correctly
Defi D EGT
Old Apr 8, 2005 | 02:31 PM
wojo's Avatar
I also see ~1500 on full throttle.
Old Apr 8, 2005 | 03:48 PM
Agent-Smith's Avatar
~1625 WOT in 4th.
Old Apr 8, 2005 | 03:55 PM
kimletrim's Avatar
Registered User
Assuming what placement of the temp probe?
Old Apr 9, 2005 | 12:33 AM
Eugene's Avatar
The EGT sensor should be installed after the cylinder head and close to turbo but in front of it. Is that case on tuned EVO you should see highest EGT close to 850C (1560F).
So when I see 600 or 700 this should be wrong istallation.
But I wanted to know, if anybody has higher EGT.
Old Apr 9, 2005 | 10:16 AM
Agreed with Eugene. Many people put them in dp's and what not. From all the racing I've been involved with, you want it pretty dern close to the cyl head (couple inches.) Much after that, readings tend to be much less reliable. With that said, I've been to a couple shops that install them in the dp...but I'm not a fan of that. One of the guys we raced with blew a few engines because he mounted the EGT too far away and was getting inaccurate (low) readings. I'm sure there are people that will disagree with this, so go for it, but mine is just far enough away that I had to have a little notch removed from the heat shield, but close enough that I couldn't drill a hole in it.
MikeyT
Oct 13, 2009 07:20 AM
dipsetinallday
29
Aug 17, 2009 09:30 PM
honki24
Jun 20, 2008 06:04 AM
Chabada15
31
Jun 12, 2008 07:01 PM
evo8dad
33
Jun 5, 2005 05:01 PM
